RV.Net Open Roads Forum: Tech Issues: Salting a Battery--Ruined It?
 > Salting a Battery--Ruined It?
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 03/13/19 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
The Hucksters added magnesium sulfate to a perfectly new discharged battery. It would strip excellent but sulfated loaded plate material and prstidigitate a phony CCA increase at the cost of battery lifespan.
Lattice linked aged sulfation is another beast altogether,
Godzilla in a rubber suit merchandising. But the gullible took it hook, line, sinker, rod & reel. Maybe the boat and lake to boot.
2112
Posted: 03/14/19 04:16am Link  |  Quote  |  Print  |  Notify Moderator
I tried the Epsom salts trick many years ago. My immediate response was "WOW, it worked." It started my car like a brand new battery. What I didn't know was every minute I left it in the battery it was eating away my plates. Within about month that battery was no longer a battery.
Maybe he can take it to a battery shop to get it flushed and properly filled but it's probably not worth it.
2013 KZ Durango 2857
Ralph Cramden
Not on this rag of a forum
Posted: 03/14/19 04:21am Link  |  Quote  |  Print  |  Notify Moderator
Salt in the battery? How about sawdust in your automatic transmission if it's slipping? Hardwood sawdust works better than pine or cedar, but the natural oils in the pine or cedar go a long way regarding corrosion prevention. Three friends and I pissed in a radiator one night after taping up a lower hose and made it home. Urine has salt in it. Maybe try taking a whiz in the battery?
* This post was edited 03/14/19 04:33am by Ralph Cramden *
2112
Posted: 03/14/19 04:39am Link  |  Quote  |  Print  |  Notify Moderator
Epsom salts is magnesium sulfate, table salt or sea salt is sodium chloride. Completely two different compounds. They share nothing in common but the word salt.
I thought the saw dust was for manual transmissions and differentials. It helps mesh worn out gears, as the folk lore goes. I remember an Andy Griffith episode when Barney bought a old car that had saw dust in the rear end.
* This post was edited 03/14/19 04:52am by 2112 *
SidecarFlip
SE Michigan
Posted: 03/14/19 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Blended monkey pickles (leave the skins on) will make your slush box shift like new (for a while) and make your car smell like a Dairy Queen when the tranny gets hot too.
Egg whites in the radiator seals leaks and sawdust in the differentials cure bad gears too.... For a while at least.
His batteries are toast, burnt toast. Time to replace and put the epsom salts back in the medicine cabinet.
A spud in the tailpipe works wonders. It seals the exhaust and your motor won't start (gasoline engine). Pulled that trick a few times when I was a kid, on people I didn't like. Shoved the spud way up the tailpipe with a broom handle.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
BFL13
Victoria, BC
Posted: 03/14/19 08:19am Link  |  Quote  |  Print  |  Notify Moderator
I didn't know that it is not salt. Learned something. Mex mentioned magnesium.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Wherever I happen to park
Posted: 03/14/19 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Water. PURE Lab grade distilled water. IS. believe it or not an insulator.
BUT WHEN YOU ADD SALE (Be it Epson or table) It becomes very conductive and .. Shorted his battery out.
There is one thing you can do about it.. Visit Costco or Sam's club and pick up a pair of brand new GC-2 batteries.. (Or Interstate or my choice is DEKA as well DEKA's are 100% US content and I like to support USA).
Home is where I park it.
GordonThree
Northern Michigan
Posted: 03/14/19 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
delete
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
DrewE
Vermont
Posted: 03/14/19 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
Electrolyte needs to be conductive for a battery to work; otherwise, it cannot conduct a current. Battery acid is quite conductive on its own. Most things (salts and acids generally) dissolved in water will make it conductive due to the ions formed in the solution; exceptions are substances such as alcohols that, while miscible with water, do not ionize when dissolving.
It's not so much that the salt water shorts out the battery, but rather (according to those here who know the chemistry far more than I do) that the salt solution attacks the plates over time.
landyacht318
Near a large body of salty water
Posted: 03/14/19 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
I'd be interested in just how much improvement and for how long afterwards before cliff diving begins, that epsom salts make.
But this info would likely just be used by used car sellers and the like, hoping to not have to put in a new starter battery before sale.
But I guess there are plenty of integrity free, something for nothing folks everywhere, so magnesium salting of rv batteries before sale is not out of the question.
