RV.Net Open Roads Forum: Tech Issues: Water pressure .
 > Water pressure .
fordman57
Posted: 03/13/19 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
Low water pressure kitchen sink. Replaced faucet still low ?
agesilaus
North Florida
Posted: 03/13/19 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Then it's not the faucet. Generally you can just clean the wire mesh filter on the end of the spout to restore flow. Are you sure the water pressure into the RV is good? A kinked line, or a plugged water filter are other possibilities. Are you using the water pump?
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
rk911
Wheaton IL
Posted: 03/13/19 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
was the pressure bad at every faucet? if you're using one of. those cheap screw on water pressure regulators know that they are easily plugged up. if you have one remove it and see if that restores pressure?
'73,
rich, n9dko
Remember...if you don’t know where you’re going you're bound to end up somewhere else.
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
Wherever I happen to park
Posted: 03/14/19 08:25am Link  |  Quote  |  Print  |  Notify Moderator
In one park I was at I had good flow from the park on a flow observation (no hose connected) but when I hooked to the RV nothign.. Turns out someone left a spigot open and the pump could not keep up.
Low flow at a SINGLE faucet indicates either a clogged faucet strainer (Replaced so we know that's not it) or a pinched line
Low flow at ALL faucets is indicitive of an RV Pressure Regulator of the 3/4" Cylinder type (Junk) Get a Valterra Adjustable and set it to 50 PSI give or take a bit or a Watts or Zurin 1/2 inch or larger in-ine with proper hose adapters.
Home is where I park it.
Matt_Colie
Southeast Michigan
Posted: 03/14/19 08:26am Link  |  Quote  |  Print  |  Notify Moderator
If the galley tap is a modern residential version of anything with a single lever control, it may be plugged up with scale from the water heater. To clear this, you may have to figure out how to take it apart and find where the internal screen is so you can get the little ball of white scale out of it.
I have to do this with ours kind of regularly.
Why doesn't this happen at home? Because that water heater is bigger and the scale can collect in the bottom.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
Second Chance
Wherever...
Posted: 03/14/19 11:00am Link  |  Quote  |  Print  |  Notify Moderator
It may not be a pressure issue. Many RV kitchen faucets have flow restrictors that limit the flow rate. Some can be removed - some can't. If this is the issue, replacement with a residential faucet should fix it.
Rob
U.S. Army retired
2016 Grand Design Reflection 337RLS
MOR/ryde independent suspension, disc brakes, LR G tires
PullRite OE 18K, Demco Glide Ride pin box
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
agesilaus
North Florida
Posted: 03/14/19 11:48am Link  |  Quote  |  Print  |  Notify Moderator
He said he already replaced the faucet
Second Chance
Wherever...
Posted: 03/14/19 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
But he didn't say if he replaced it with another RV faucet (which will probably have a flow restrictor in it) or a residential faucet.
Rob
agesilaus
North Florida
Posted: 03/14/19 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
Rob
That's true
 > Water pressure .
