RV.Net Open Roads Forum: General RVing Issues: License plate location ?
 > License plate location ?
Gunther1369
Ironwood, MI
Posted: 03/13/19 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
hi, I just bought a new 2019 camper, graywolf 20rdse, and I noticed that the license plate mount under the tail light is on the passenger side.
I have looked up other graywolf campers and they are on the left or the right, so what side is it suppose to be on, the ones I had in the past were on the drivers side, so does it mater ?
2019 Cherokee Grey Wolf 20RDSE
rk911
Wheaton IL
Posted: 03/13/19 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
display the plate unobstructed in the space provided.
'73,
rich, n9dko
Remember...if you don’t know where you’re going you're bound to end up somewhere else.
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
DrewE
Vermont
Posted: 03/13/19 10:40pm Link  |  Quote  |  Print  |  Notify Moderator
The plate goes under whichever taillight has the license plate light shining out from it. If they both do and both offer an unobstructed view of the plate, I don't think it really matters which side it goes on...but I believe typically only one trailer taillight is equipped with the plate light.
valhalla360
No paticular place.
Posted: 03/14/19 12:39am Link  |  Quote  |  Print  |  Notify Moderator
If it really bothers you, google your state vehicle code. It has details on what is required.
But 99.9999% chance it's fine, it's legal and no one will ever question it.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Ralph Cramden
Not on this rag of a forum
Posted: 03/14/19 04:11am Link  |  Quote  |  Print  |  Notify Moderator
The plate mounting tabs are usually molded into the base of the light fixture itself, which is the cheapest obtainable, and at some point will probably break off given enough time. What side it is on depends on who installed it more than what side the manufacturer intended for it to be installed. Isaiah Yoder may have put them on the right on Tuesday, but Levi Beiler may have slapped them on the left on Wednesday. Typically the light is just part of the cover / lens and interchangeable between the two.
bucky
Raleigh metro
Posted: 03/14/19 04:33am Link  |  Quote  |  Print  |  Notify Moderator
I would visit multiple dealers in multiple states to check real life locations. As I'm sure that you are aware ad agencies often reverse pics as the ad layout requires for best presentation negating your research on the matter.
You're kidding, right?
2005 Cummins 2500 2WD LB quad cab pulling a 2007 Jayco 345bhs. It pulls better than Marcell Ledbetter's mule.
Oldmaple
West Michigan
Posted: 03/14/19 04:49am Link  |  Quote  |  Print  |  Notify Moderator
Doesn't matter where it is. Must be mounted horizontally on the rear of the vehicle and lit when it is dark. The plates are read automatically by a trailing police vehicle and the scanner will find it, wherever it is.
BarneyS
S.E. Lower Michigan
Posted: 03/14/19 07:53am Link  |  Quote  |  Print  |  Notify Moderator
Mine is on the right side. The ladder is on the left side. Never a problem in 15 years.[emoticon]
Barney
2019 Ram Limited 1500, 5.7L Hemi, 4x4, SB
Not towing now.
Wherever I happen to park
Posted: 03/14/19 08:29am Link  |  Quote  |  Print  |  Notify Moderator
The side does not matter. As RK said it has to be clearly visible.
Right. left, center. low high.. Does not matter (well not too high)
SO long as a cop 500 feet behind you can read the plate. IT has to be LIT at night. so many tail lights have a clear "Window" in the bottom of the assembly and a license plate mount under the window. Others will have a light dedicated to the plate (My RV does)
Had a ton of fun last summer.. Blew a few fuses. one was that lamp. (And others on the circuit).
Home is where I park it.
Charlie D.
E. Texas-Orange
Posted: 03/14/19 08:46am Link  |  Quote  |  Print  |  Notify Moderator
Yes. Plastic tap for mounting the license broke one time and I lost the plate. Second time one tab broke and license was dangling on the other. I used two hose clamps and mounted it to the ladder. I do not have a light shining on it at night but I never drive at night.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
