RV.Net Open Roads Forum: Fifth-Wheels: Airbag assist rear suspension??
 > Airbag assist rear suspension??
ENG2242
Missouri.
Posted: 03/14/19 08:02am Link  |  Quote  |  Print  |  Notify Moderator
I’m gonna be getting our Fifth wheel, and I wanted to add an airbag suspension to my 2007 Dodge ram 2500 Cummins. Are there any kiits after market that you guys would recommend. I’m not looking to go cheap on this. I’m not overloaded I just need to raise the rear end up about an 1.5 to 2 inches. I don’t want to add an additional early spring because the every day drive would be like riding in a dump truck. If anyone has any recommendations please Provide them. Thank you so much and God bless. David
David Hartmann
2018 Bighorn 3870FB
2007 Dodge Ram 2500 CTD 5.9
Prodigy 2
Auto-Slide Hitch
Firestone Air-Bags
garyp4951
TN
Posted: 03/14/19 08:10am Link  |  Quote  |  Print  |  Notify Moderator
air bags
Super_Dave
Harrisville, UT
Posted: 03/14/19 08:26am Link  |  Quote  |  Print  |  Notify Moderator
My 06 Dodge has Firestone bags with the manual inflate. Pretty easy to install.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
RollandB
Albany, Or
Posted: 03/14/19 08:35am Link  |  Quote  |  Print  |  Notify Moderator
I put Firestone’s on our prior truck, never liked the harsh ride when empty and lowered the psi to the recommended minimum.
The truck we have now is outfitted with a Timbrens. Empty I can tell no difference in ride and they keep it level when the fifth wheel is connected. It might be worth checking out
2005 Silverado 3500 Crew Cab Long Box, Duramax/Allison, B&W Companion, TST507's
2016 Artic Fox 27-5L
lee worsdell
elmvale
Posted: 03/14/19 08:42am Link  |  Quote  |  Print  |  Notify Moderator
Ya I have firestone also. I put maybe 50lbs in towing just enough to raise truck back to where it was when iam not hooked up.
rhagfo
Portland, OR
Posted: 03/14/19 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Is you truck leveled? I never found a need for bags on our 2001 Ram 2500 when carrying/towing our 12,500# 5er with a 2,700# pin.
ford truck guy
Pennsylvania
Posted: 03/14/19 09:05am Link  |  Quote  |  Print  |  Notify Moderator
If you go with Air Lift, get the wireless system... you cab adjust the ride with a wireless remote while driving if need be... .
Me-Her-the kids
2015 Ford F350 SD 6.7
2020Redwood 3991RD Garnet
Cummins12V98
on the road
Posted: 03/14/19 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Does your truck set "LEVEL" or slightly rear high when loaded??? If so leave it alone, that's how it's supposed to be when loaded. Add Bilstein shocks and carry on.
If rear is lower than level look into PacBrake bags.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Durb
NW
Posted: 03/14/19 09:30am Link  |  Quote  |  Print  |  Notify Moderator
I installed Firestones on my 04 with manual inflate/deflate, took less than an hour. They do what they were designed to do. Auto inflate would be a nice convenience. Keeping the bags at minimum air is an inconvenience. I installed mine with separate air chucks, I'm considering teeing the lines together to balance the pressure and provide a single fill point. Leaning and unbalanced loads are not issues for me.
topjimmy
Washington Coast
Posted: 03/14/19 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
Yep Firestone air bags for me on my last 2 Trucks love them and pump them up to 45 P.S.I. when loaded for my 14K 5er 3K pin Weight to keep it nice and level then back down to 5 P.S.I. when not to smooth the ride out
2015 Montana 3735MK Legacy,2004 3500 GMC Short Bed, LB7 Duramax/Allison ,Pacbrake,Firestone Airbags Bullydog Tuner
