RV.Net Open Roads Forum: Fifth-Wheels: Airbag assist rear suspension??
 > Airbag assist rear suspension??
cummins2014
Utah
Posted: 03/14/19 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
DBHMEH wrote:
I’m gonna be getting our Fifth wheel, and I wanted to add an airbag suspension to my 2007 Dodge ram 2500 Cummins. Are there any kiits after market that you guys would recommend. I’m not looking to go cheap on this. I’m not overloaded I just need to raise the rear end up about an 1.5 to 2 inches. I don’t want to add an additional early spring because the every day drive would be like riding in a dump truck. If anyone has any recommendations please Provide them. Thank you so much and God bless. David
Have had both firestone ,and Airlift, pick your brand.
I presently have the Airlift Load Lifter 5000 with the jounce system, with the Airlift 72000 compressor system, with the wireless remote control. IMO the only way to go as far the compressors go . No in- cab wiring, air lines, and gauge to mess with. Touch of a button to inflate ,and deflate. Automatically maintains the set air pressure, no worries about running the airbags with no air.
cummins2014
Utah
Posted: 03/14/19 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
ford truck guy wrote:
If you go with Air Lift, get the wireless system... you cab adjust the ride with a wireless remote while driving if need be... .
The only way to go if wanting the compressor. Great setup
rhagfo
Portland, OR
Posted: 03/14/19 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
What year and model of 5er? The need for air bags is some what dependent on the pin weight of the 5er. While you don't have the 5er yet, make and model will give an idea of dry pin and then wet can be approximated from that weight.
Cummins12V98
on the road
Posted: 03/14/19 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
I have Firestone air bags with two skinny leaf springs each side. My rear axle weight is only 9,750#
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
rhagfo
Portland, OR
Posted: 03/14/19 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
Are they Firestone or Ram air bags?? The one option I wish the 2016 had!
transamz9
Lawrenceburg Ky
Posted: 03/15/19 03:59am Link  |  Quote  |  Print  |  Notify Moderator
Original poster, if you truly don't want to go cheap and plan on keeping your truck you can do what I did and go 4 link suspension with full air ride. I do not have springs on my 05 Ram. Imo, it's the only way to go for complete control over ride and handling.
2016 Ram 3500 Mega Cab Limited/2013 Ram 3500 SRW Cummins(sold)/2005 RAM 2500 Cummins/2011 Sandpiper 345 RET (sold) 2015 Sanibel 3601/2008 Nitro Z9 Mercury 250 PRO XS the best motor made.
schlep1967
Harrisburg, PA
Posted: 03/15/19 06:59am Link  |  Quote  |  Print  |  Notify Moderator
Firestone's for me also. 5 lbs when not towing and around 22 lbs when towing. Many tend to over inflate the air bags for the load they are carrying. Firestone says every 1 pound of pressure will support 40 pounds of weight. If you already have a 3/4 ton (1500 lb) truck and you put a 2500 lb pin weight on it you only really need another 1000 pounds of support. 25 X 40 equals 1,000. Going higher than what you actually need just makes for a rough ride and applies more shock to all the components of the truck and trailer.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
IdaD
Idaho
Posted: 03/15/19 08:17am Link  |  Quote  |  Print  |  Notify Moderator
I have Timbrens on my truck and prefer them to bags. No change in the unloaded ride but it firms things up nicely when fully loaded, and they're simple and require no maintenance or adjustments.
2015 Cummins Ram 4wd CC/SB
Cummins12V98
on the road
Posted: 03/15/19 08:26am Link  |  Quote  |  Print  |  Notify Moderator
They are made by Firestone supplied OE from RAM.
Friends that have a 3500 15 RAM DRW just rode with us to dinner and then were impressed with the ride.
memtb
Wyoming
Posted: 03/15/19 09:49am Link  |  Quote  |  Print  |  Notify Moderator
DBHMEH, On our 2007 Ram 3500 SRW Cummins, we went with the Firestone system with the pump. Easy install, easy to use. Our 5er has a lot of pin weight, and we could not consider towing without. Our truck was sprung so soft, the first time we towed at night (right after we got the trailer), we used low beams to be able to see the road, lighting pattern was like high beams. When we met an oncoming vehicle, we went to high beams to put the lights “over” the approaching vehicle. The road in front of us was dark...NO LIGHT ON THE ROAD! One trip.....and we were buying air bags!
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
