RV.Net Open Roads Forum: rear camera install
gpeade
VA
Posted: 03/14/19 10:15am Link  |  Quote  |  Print  |  Notify Moderator
Asking for advise here. I have a Jayco TT with Fiberglass sides. I want to add a rear view camera to the back of it. I would prefer to go hardwired over wireless for the reliability. I have no problem running the wires the length on the unit underneath. My concern is how would I get them from the camera down underneath the unit? I'm not going to tear out an interior wall just to fish this cable down. I can get surface applied wire raceway that is made for exterior that wouldn't look too bad back there but I would prefer the wire be hidden completely. Anyone know an easy way to run this wire from the camera to the bottom of the unit?
Second Chance
Wherever...
Posted: 03/14/19 10:53am Link  |  Quote  |  Print  |  Notify Moderator
My best "advice" would be to go with wireless. We have used one for over 3.5 years with no reliability issues at all. The installation is far simpler and there's one less thing to mess with when hitching or unhitching.
Rob
U.S. Army retired
2020 Solitude 310GK-R
MORryde IS and disc brakes
Solar
(Previously 4 yrs, 9 mos full-time in a Reflection 337RLS)
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Fire19
Michigan
Posted: 03/14/19 10:58am Link  |  Quote  |  Print  |  Notify Moderator
Second Chance What type of Wireless unit did you use?
2000 Ford F-350 Dually Crew Cab
2002 Gulfstream Seahawk 29FKS
1998 GL1500SE
Second Chance
Wherever...
Posted: 03/14/19 11:15am Link  |  Quote  |  Print  |  Notify Moderator
It's a Furrion (still use it). Our Grand Design fifth wheel came with the mount and power connection for Furrion already in place. If that's not already there, it's very easy to get power from the top center clearance light on the RV when installing it yourself.
That said, a rear camera is not the end-all for backing up - my wife still stands back there with a two-way radio when backing into tight spots. I find the camera very useful, though, for double-checking clearance when pulling back over after passing a semi and situations like that.
Rob
2edgesword
New York
Posted: 03/14/19 11:26am Link  |  Quote  |  Print  |  Notify Moderator
We use this one on our 32.5' TT...
Yuwei Rear Observation Camera
Works great and it's about half the price of the Furrion model
riven1950
NC
Posted: 03/14/19 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
I am not an expert but do have 2 experiences with BU cameras.
1- I installed a Camecho on our previous TT. Installed it wireless.
pros- less than 100$
better screen image than my current Furion 7" vs 4"
cons- poor reception wireless . I think if It was installed wired it would be fine, although more trouble to install. I ended up installing the wireless transmitter in the front of the TT and it worked great
2- Current GD TT came ready for a Furrion
pros- Easy peasy to install
Wireless works great
cons- Screen is only 4" and hard to see. I think they have a 7" screen version, if so I would definitely buy it
price is way too high, paying for convenience
If my Furrion had a 7" screen I would be really happy with it. I don't really use it much for backing up mainly for observing while driving.
I would not go to the trouble of installing a camera wired. Just too much trouble for me although it should work fine
garyemunson
Reno, Nevada
Posted: 03/14/19 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
Once you have a rear camera you won't want to be without it. Our situation is slightly different with a Class A. It originally displayed on the radio screen (about 5") but it was low on the dash and not easy to see. Bought a 7" monitor from eBay, mounted it to the side on the dash, and changed the wiring for it to always display. Ours is currently wired but have had wireless units in the past with no problems. Would be much easier to install.
phemens
Montreal, Canada
Posted: 03/14/19 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
an easy path to the undercarriage is to route the wire across the roof to the fridge vent then fish down and drill a hole up from underneath. Caulk it and you're done...
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1Kw solar, 500 AH LIFePO4, Yamaha EF2000 gen, Samlex 3000w Inverter
JJnLilly
Ohio
Posted: 03/15/19 05:42am Link  |  Quote  |  Print  |  Notify Moderator
I hardwired mine. Went through the hitch and under, tucking the wire under the duraplast bottom then up the back. I have a center mounted ladder so connected mine under one of the steps.
2007 Ram 2500 QC CTD
2014 Open Range 337RLS
sgfrye
north carolina
Posted: 03/15/19 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Rob
this is our experience also.
first TT was 33ft, current is 37ft
i removed the furrion from previous TT and installed on current. works great rarely drops signal. wish screen was larger. use wife to spot backing in spots also
