RV.Net Open Roads Forum: Tech Issues: Suburban LP water heater malfunction, need help.
 > Suburban LP water heater malfunction, need help.
Hemi Joel
Minnesota
Posted: 03/14/19 10:19am Link  |  Quote  |  Print  |  Notify Moderator
Hi, I am on a road trip with my 2018 Eagle Cap 1165, and the water heater has malfunctioned. I hope someone can help me with info to get it running. It is a Suburban SW6D, SN 171504878. LP only, no 110v. Last night I noticed that it lit and shut off about 3 times, then stayed unlit. The fault light next to the switch remains lit when ever the switch is on. This morning, I turned off the switch inside the camper for a while, then when I turned it back on, I could hear the gas valve solenoid open and close 3 times, but no flame. I went outside and opened the cover of the water heater, and pressed the reset button, but could not feel any movement of the button. (under a rubber cover) Then I turned off the switch inside the camper to reset the start up cycle, and when I turned it back on, I ran outside to observe. The gas valve was opening, but no spark to light it. The next time the gas valve opened, I lit it with a lighter, and it fired, but only for a couple seconds and then the gas valve shut. I repeated this process a couple times, with the same results.
The batteries are fully charged, and there is 1-1/4 bottles of propane. The furnace and the stove both operate properly, proving a proper gas supply. I hate having to go to a dealer for repairs, especially on a road trip with a schedule. I have tools, a digital multi meter, and good mechanical/electrical skills. But it would be good to hear from the voice of experience before I go any further.
Thanks,
Joel
2018 Eagle Cap 1163 triple slide on a 93 Dodge D350 Cummins, DTT 89 torgue converter, big turbo, 3 extra main leafs, Rancho 9000s rear, Monroe gas magnums front, upper overloads removed, home made stableloads, bags.
Harvard
51.6N 114.7W
Posted: 03/14/19 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Deleted, miss read OP, sorry
Hemi Joel
Minnesota
Posted: 03/14/19 11:14am Link  |  Quote  |  Print  |  Notify Moderator
I just removed the cover from the thermostat and check it with the VOM. 12.6 volts on both terminals, confirming that it is functioning and calling for heat.
enblethen
Moses Lake, WA
Posted: 03/14/19 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
Gas valve operating would indicate that there is power to the circuit board.
Have helper turn on water heater while you are at the unit. Listen for ignitor to spark.
You could have a helper turn on water heater while you use a long lighter to ignite gas inside burner area. Becareful as it could flash back!
Check the ignitor for proper spacing. Disconnect the ignitor wire, test it for conituity.
Check the porcelain on the ignitor for cracks.
Call Suburban for local repair person or shop. It could be bad circuit board. Could be still under warranty!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Old-Biscuit
Verde Valley
Posted: 03/14/19 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
Got good DC otherwise gas valve solenoids would NOT be energized/valve opening
NO Spark........
You have either:
Bad ground
Bad spark electrode
Bad electrode wire connections
Bad circuit board
12V DC Circuit
Inspect electrode for crack in porcelain, proper gap (1/8”)or carbon build up on tip, ensure that spark is present at electrode tip, inspect burner for debris, inspect electrode wire for short (including against the back side fo the appliance door when in closed position), check electrode wire connections...clean/tight
Replace electrode.....otherwise circuit board is faulty
Electrode part number --- Suburban 232258
Circuit board part number..Suburban 520814
enblethen
Moses Lake, WA
Posted: 03/14/19 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
If you replace circuit board, I would recommend a Dinosaur Electronics version.
wnjj
Cornelius, Oregon
Posted: 03/14/19 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
The spark electrode also functions as a flame sensor so even when lit by hand it will not stay if it can't sense the flame.
Hemi Joel
Minnesota
Posted: 03/14/19 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Problem solved! first I tried putting in a new electrode, even though the old one looked pretty good. Because it was a lot cheaper than buying a module. That didn't do it, so I put in a new module, and it fired right up. Thanks for all the help!
enblethen
Moses Lake, WA
Posted: 03/14/19 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the update!
steved28
Bellingham,MA,USA
Posted: 03/26/19 09:28am Link  |  Quote  |  Print  |  Notify Moderator
X2
If you replace it with the OEM Chinese junk board, it will most likely fail again... and again... With no warranty.
Dinasour stands behind their boards, are made in the U.S. , and are just plain a better design with a much better reputation.
2019 Winnebago Sunstar LX 35F
2000 Jeep Wrangler TJ Sahara
