RV.Net Open Roads Forum: Tech Issues: Inverter Doesn't Turn On
 > Inverter Doesn't Turn On
Lakejumper
Northern California
Posted: 03/14/19 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
I'm dry camping and tried to turn on the inverter and am not getting power. I have the Xantrex XM1000. It worked fine 5 weeks ago when dry camping. I was able to use all of the AC plugs when I was hooked to shore power several days ago. All of the AC plug receptacles work when the generator is on. The GFCI plug on the inverter and the 15 amp button appear to be okay. I plugged/unplugged the cable from behind the remote panel and still no power at the remote panel. My question is if the inverter is bad, why would the plugs work with the gennie on in the RV. Or, could I have a bad remote panel? It plugs into some type of inline coupler.
* This post was edited 03/14/19 08:06pm by Lakejumper *
Lakejumper
2016 Winnebago Vista LX 30T
enblethen
Moses Lake, WA
Posted: 03/14/19 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
The inverter may have a bypass relay that allows shore power or genset power to pass.
Check for incoming 12 volts DC to the inverter. Possible blown input fuse or maybe a wire disconnected.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
MDKMDK
Canada
Posted: 03/14/19 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
In our Navion, the generator feeds the AC side of the electricals to light up the AC coach receptacles. No inverter required when we run the generator or are plugged into shore power. If I understand it correctly, the inverter draws 12V from the batteries and then turns it into AC and feeds a few of the same receptacles that will run off the generator or shore power. That's probably why the receptacles are hot when you run the generator. If you're not getting AC at those same receptacles when not on shore or generator, the problem is with the inverter and 12V batteries side of things. If our coaches are designed basically the same electrically? Caveat: I'm not an expert nor an electrician.
Mike.
enblethen
Moses Lake, WA
Posted: 03/14/19 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
This should be the manual for your inverter.
Manual
Lakejumper
Northern California
Posted: 03/14/19 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
I’m thinking that it may bypass the gennie but not when on shore power because I have lost power to the receptacles fed by the inverter before while on shore power. At that time, I reset a breaker on the the inverter itself.
* This post was edited 03/14/19 08:08pm by Lakejumper *
Lakejumper
Northern California
Posted: 03/14/19 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
Enblethen- I’ve read the manual and it states to check the power at the inverter. Unfortunately, it’s too difficult to get to and we’re traveling. I’m hoping to find out if there is another fuse/circuit breaker somewhere else to check.
enblethen
Moses Lake, WA
Posted: 03/14/19 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
Look around the batteries for a large fuse.
You maybe able to trace wires back to batteries.
Has any battery work been done?
2oldman
New Mexico
Posted: 03/14/19 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
Inverters sometimes need a reboot. You do that by disconnecting either the + or - cable and waiting a few minutes before reconnecting. There could be a large spark when reconnecting.
bid_time
Michigan
Posted: 03/14/19 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
It's pretty simple, you got to check power in and power out at your inverter. That will tell you where the problem is. You're just guessing.
Lakejumper
Northern California
Posted: 03/14/19 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone for your help. I think I need to wait until I get back home and troubleshoot to see if power is coming into and out of the inverter. In the meantime, I will look for a fuse.
