RV.Net Open Roads Forum: Tech Issues: Inverter Doesn't Turn On
 > Inverter Doesn't Turn On
Wherever I happen to park
Posted: 03/15/19 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Make sure you have good 12vdc. and .. On some Xantrex models (not all) there is a switch ON THE INVERTER which I call "Big Red" (it's big may or may not be red) and if it's off. it's off and I mean OFF. no power goes anywhere at all.
Home is where I park it.
Lakejumper
Northern California
Posted: 03/15/19 11:07am Link  |  Quote  |  Print  |  Notify Moderator
Found the problem!! No 12volt to the inverter as the battery cable terminal to the inverter circuit breaker in the battery compartment had snapped off! When I opened the compartment to look for a breaker, I saw the cable broken and pulled away. I wouldn't have known the breaker was for the inverter otherwise.
Thanks again to all for your quick responses. I just wish that Winnebago had placed the inverter in a more accessible location to troubleshoot this problem on the road!
Lakejumper
2016 Winnebago Vista LX 30T
enblethen
Moses Lake, WA
Posted: 03/15/19 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the update!
Rigs are built for quick cheap construction and nothing for maintenance.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
time2roll
Posted: 03/15/19 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
Snapped off?
Consider some better built cables....
http://www.genuinedealz.com/custom-cables
675w Solar pictures back up
