RV.Net Open Roads Forum: Tech Issues: solar array charging ?
 > solar array charging ?
blueh20
montana
Posted: 03/14/19 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
A solar newbie,
I have 3 100w renolgy eclipse panels and a renolgy 40amp commander controller.
A 255ah lifeline battery.
I do have a breaker between my pv panels and the commander.
Am wondering , when the commander is flashing green lights, which mean, pv is charging the battery and the other green flashing means battery is fully charged should I throw the breaker and disconnect the pv array from the commander just to be on the safe side.
thanks
BFL13
Victoria, BC
Posted: 03/14/19 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
No. Leave it to do its job.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Boon Docker
Posted: 03/14/19 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
As BFL says, no need to disconnect the array from the controller. Even when plugged into shore power you can leave the array and controller on to do it's job.
blueh20
montana
Posted: 03/14/19 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, great,will leave it alone and let it do its job, thanks
BFL13
Victoria, BC
Posted: 03/14/19 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
That is a rebranded EPSolar Tracer controller, which is a good one. It gets the batteries to Absorption voltage (for AGM or else you can change that with the 50 remote) and holds it for two hours then drops to Float voltage. Good in most situations, or you can fix to your needs with the remote.
Good to have the breaker! Big warnings about that in the manual to not ever have no battery with array connected.
https://images-na.ssl-images-amazon.com/images/I/B1ma7znmYxS.pdf
blueh20
montana
Posted: 03/14/19 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, I have read the warnings about not having a battery hooked to the controller before the pv array is hooked up.
pianotuna
Regina, SK, Canada
Posted: 03/14/19 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
Error Error! The battery MUST be connected before the panel. Failure to do so may let out the magic blue smoke from the controller.
Regards, Don
blueh20
montana
Posted: 03/15/19 05:16am Link  |  Quote  |  Print  |  Notify Moderator
Yes,that's what I was trying to say, ,,battery always hooked to controller first,
Thanks
2oldman
Salton Sea
Posted: 03/15/19 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Renogy. Breaker is not needed unless that's just acting as a convenience switch. At least I haven't heard of 'solar panel surge.'
time2roll
Posted: 03/15/19 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Would be helpful to have an actual voltmeter instead of just a few flashing green lights.
675w Solar pictures back up
