RV.Net Open Roads Forum: Tow Vehicles: Dual Wheel Valve Stems
Search only in Tow Vehicles
 > Dual Wheel Valve Stems
allen8106
Burrton. KS
Posted: 03/14/19 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
Hey guys, for those of you who run duallys on your truck how do you deal with the hassle of adding/checking the air in your rear tires? I’m considering some valve stem extensions or some all new metal valve stems that are long enough to air up easily.
Thoughts?
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
1983 DW (love of my life)
2010 Pit Bull Terrier (Jake)
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
Big Katuna
Deland, FL
Posted: 03/14/19 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
Borg valve stems. You have to take the tires off and replace your existing stems.
My Kharma ran over my Dogma.
fj12ryder
Platte City, MO
Posted: 03/14/19 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
Just get the correct air pressure gauge and it's no big deal. Adding air is the same thing.
I've had three different sets of extensions, and all three leaked. One set leaked immediately, one leaked after a couple months, and one set lasted nearly three years, but also rubbed on the sidewall of the tire and darned near wore through the sidewall. Now I just use a proper tire pressure gauge.
Howard and Peggy
"Don't Panic"
Super_Dave
Harrisville, UT
Posted: 03/14/19 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
I do this, a 2 sided gauge. The biggest problem that I've had is Les Schwab techs being smart enough to offset rear wheels when having them rotated and in a couple of instances, removing the valve cap on the inner tire.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
Cummins12V98
on the road
Posted: 03/14/19 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
Double ended airchuck and pressure gauge. ZERO ISSUES.
BTW LesSchwab and Smart Techs don’t belong in the same sentence.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
blt2ski
Kirkland, Wa
Posted: 03/14/19 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
Correct head, and pressure gauge as mentioned. No issues in 30 years of owning a DW rig of some sort!
Marty
Check RV.Net Blogs at: blog.rv.net
Campinghoss@51
Windsor NC
Posted: 03/15/19 04:24am Link  |  Quote  |  Print  |  Notify Moderator
I went to a local auto parts store and purchased the all in one chuck. The chuck fits both ways as needed and after adding air it gives you a instant air reading. No issues and much cheaper and reliable than extensions.
Camping Hoss
2017 Open Range 3X 388RKS
2017 F-350 6.7 with hips 8'bed
Lucky & Lucie
blownstang01
Upstate NY
Posted: 03/15/19 05:09am Link  |  Quote  |  Print  |  Notify Moderator
I have the dual ended gauge and air chuck, but the holes in my wheels are too small to get my hands in to get the caps off. Borg brass stems, best $110 I ever spent.
Super_Dave
Harrisville, UT
Posted: 03/15/19 06:40am Link  |  Quote  |  Print  |  Notify Moderator
You must be a Les Schwab customer too. No caps.
Cummins12V98
on the road
Posted: 03/15/19 08:29am Link  |  Quote  |  Print  |  Notify Moderator
OE inner valve stems work great on my RAM with no cap to remove.
