RV.Net Open Roads Forum: Tech Issues: An observation about Magnum hybrid inverters
 > An observation about Magnum hybrid inverters
pianotuna
Regina, SK, Canada
Posted: 03/14/19 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all,
I'm back in the RV for a road trip. I had disconnected the Magnum from the battery bank for storage. I forgot to reconnect.
The Magnum would not pass 120 volts without being connected to the battery bank.
It (and I) survived.
Regards, Don
jharrell
Safety Harbor, FL
Posted: 03/15/19 06:11am Link  |  Quote  |  Print  |  Notify Moderator
Interesting I thought it would function if it had either 120 or 12, not good if something happens to 12v but need 120v and have the whole coach running through the inverter like me.
2016 Winnebago Vista 31be - Blue Ox Rear Track Bar - Centramatic Wheel balancers
2016 Jeep Wrangler Unlimited Rubicon Toad - Readybrute Elite Towbar
BFL13
Victoria, BC
Posted: 03/15/19 06:55am Link  |  Quote  |  Print  |  Notify Moderator
This came up before when it turned out that you can't run the 12v off the charger in an inverter/charger like you can with a converter and no battery. It seems the inverter/charger needs 12v from the battery to operate at all.
Another good reason to have separate inverter and converter.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Wherever I happen to park
Posted: 03/15/19 07:21am Link  |  Quote  |  Print  |  Notify Moderator
If I had to guess I'd say it is like the Air Conditioner. Now if your A/C has a Wall Thermostat of if it is a Carrier Air V with a I/R Remote... YOu need 12 volts for CONTROL.. Same with the inverter more than likely.
NOT all are like that.
Home is where I park it.
pianotuna
Regina, SK, Canada
Posted: 03/15/19 08:45am Link  |  Quote  |  Print  |  Notify Moderator
wa8yxm,
No there was twelve volt power to the Magnum remote. Just not to the charge and discharge terminals on the Magnum.
GordonThree
Northern Michigan
Posted: 03/15/19 08:48am Link  |  Quote  |  Print  |  Notify Moderator
Somewhere in the manual, I'm pretty sure I recall a warning to never connect the 120v supply without the 12v supply already hooked up.
Glad to hear there weren't any fireworks.
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
2oldman
Salton Sea
Posted: 03/15/19 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Yes, that makes sense.
pianotuna
Regina, SK, Canada
Posted: 03/15/19 10:51am Link  |  Quote  |  Print  |  Notify Moderator
It is just another reason to do a "patch board" installation.
I can move plugs and in 20 seconds bypass the Magnum altogether.
time2roll
Posted: 03/15/19 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Why disconnect in storage? Why not just connect the Magnum back up before you roll?
675w Solar pictures back up
pianotuna
Regina, SK, Canada
Posted: 03/15/19 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
Hi time2roll,
I have disconnect switches--the Magnum does have a parasitic load--so I disconnect for long term storage. I simply forgot to turn it back on. mea culpa.
