RV.Net Open Roads Forum: Vinyl plank flooring - snap lock with history of success?
 > Vinyl plank flooring - snap lock with history of success?
PartyOf Five
Wheaton, IL
Posted: 03/15/19 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
We bought and installed something from Lowe's and put it in last fall. So far it has done well but it was definitely time consuming to install. End result is really nice with a stone type look and very fast to lay down full boards as well as cutting to the edge. Given the small space there were plenty of cutouts and because we didn't remove everything first we had to trim around the kitchen cabinets and so forth. For an older RV, it is definitely a big upgrade from the carpeting and linoleum options
Da Moose - 2001 Dutchman 31' on E450
myredracer
Langley B.C.
Posted: 03/16/19 12:46am Link  |  Quote  |  Print  |  Notify Moderator
Besides a perimeter expansion gap, make sure the floor planks can move everywhere and don't get hung up on screws for dinette table flanges and entry door threshold, toilet, etc. Where there were screws into the floor, I made the holes in the planks larger so they could also move at those points due to seasonal temp. changes. Don't caulk the perimeter gap as I have seen some do, allow 1/4" +/- and cover with a "baseboard" strip of wood as needed.
Walls and cabinetry are often not in very straight lines and it's a good idea to scribe the cut lines where needed using painter's tape. That way you'll get a consistent even gap.
I hate CAPTCHA. CAPTCHA sux. CAPTCHA is evil. CAPTCHA needs fixing.
Gil, Deb & Dougal the Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH
2009 F250 super duty, V10, 8' bed, Hawkshead TPMS
dcason
New York
Posted: 03/16/19 04:09am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for your good ideas...all of you.
I still hold out hope that when we remove carpet the lino will look good but if not will
do the vinyl plank. Hubby saw lino under the dining bench seats so we are thinking it maybe be throughout...at the price of it, much easier for Jayco to just lay down a sheet then spend time fiddling with cutting.
Donna
Our Blog
BarneyS
S.E. Lower Michigan
Posted: 03/16/19 07:51am Link  |  Quote  |  Print  |  Notify Moderator
I have toured the Jayco factory twice. They lay the linoleum down just as soon as the wood floor is on. Everything - walls, cabinets, furnishings etc. -
is put on top of that. You should have linoleum under your carpet. It only takes them about 2 minutes or so to get it down and installed on each frame.
Barney
* This post was edited 03/16/19 08:13am by BarneyS *
2019 Ram Limited 1500, 5.7L Hemi, 4x4, SB
Not towing now.
jesseannie
Roseburg, OR
Posted: 03/16/19 08:45am Link  |  Quote  |  Print  |  Notify Moderator
I installed "luxury vinyl plank" in my older TT I lived in the northern tier at the time and it has gone through the hot and freezing weather. No problems at all. Easy to install and easy to maintain. I would recommend highly. All the manufactures say not to do it, but that is purely CYA stuff the corporate attorney writes.
Jesseannie
Cummins12V98
on the road
Posted: 03/16/19 09:21am Link  |  Quote  |  Print  |  Notify Moderator
^^^^^^ I agree, LVT "Luxury Vinyl Tile" is extremely durable, so much so we used it in mANY Dental Clinics. BTW it is a glued down product, no snap n lock/floating BS.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
dcason
New York
Posted: 03/16/19 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the Jayco factory tour info...we suspected. MAYBE we won't have to do anything for awhile except lift the carpet. Then a year or so do vinyl.
donna
blownstang01
Upstate NY
Posted: 03/16/19 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
jplante4 wrote:
Allure with Grip Strip from HoD. About $300 of material. Not recommended for installation in a non-climate controlled environment, but it's been through all 4 seasons twice now in the northeast now and it looks the same as these pics.
Leave a 1/4 inch gap around the edges and make sure NOTHING gets fastened through the vinyl into the subfloor. This means cutting around seats and sofa brackets etc and double stick taping the edge trim to the vinyl. The floor has to move as a unit, else it will buckle.
That looks great. Nice job.
dcason
New York
Posted: 05/14/19 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
I could not find this conversation so started another one....
Turns out the linoleum did NOT cover the whole floor...about 2 feet short of the cab area.
We are contemplating next steps.
Hubby is thinking vinyl plank...after he got over the crankiness.
MrWizard
Traveling
Posted: 05/14/19 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
i put pergo red oak Hardwood Plank interlock (not vinyl or glue strip)
in a previous RV is 2009
i saw the RV (2) months ago, the Pergo flooring still looks good
Radiate The Happy
1997 F53 Bounder 36s
