RV.Net Open Roads Forum: Travel Trailers: Cotter pin size?
 > Cotter pin size?
plasticmaster
Home
Posted: 03/15/19 11:12am Link  |  Quote  |  Print  |  Notify Moderator
I'm headed to hardware store to get cotter pins to repack my wheel bearings. Does anyone know the typical size cotter pin used for the castle nut? I'm at work right now and don't have access to camper. Thanks.
2oldman
New Mexico
Posted: 03/15/19 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
Hardware store should know.. or google.
Iraqvet05
Greenwood, MO
Posted: 03/15/19 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
This probably varies by manufacturer and axle rating but try a 1/8" x 1 3/4" first. I pulled that size from Dexter.
2017 Ford F-250 6.2 gas
2018 Jayco 28BHBE
US Army veteran
SidecarFlip
SE Michigan
Posted: 03/15/19 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
Get an assortment they are cheap.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
D.E.Bishop
Eagle Rock, CA
Posted: 03/15/19 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
Not to hijack the thread because he got the best answer, buy the assortment package. But to continue, without using any help, who invented the cotter pin, the correct name for which is cotter key, and what were they originally used for?
The answer may surprise you.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
bob213
Fresno, CA
Posted: 03/15/19 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
2" x 1/8 for my 3500lb axles
Edited to correct [emoticon]
* This post was edited 03/16/19 11:04am by bob213 *
opnspaces
San Diego Ca
Posted: 03/16/19 01:20am Link  |  Quote  |  Print  |  Notify Moderator
Honestly if the bearings are adjusted correctly there is no turning force on the nut. Unless you destroy the original you can probably get away with reusing it.
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
JIMNLIN
Oklahoma
Posted: 03/16/19 08:54am Link  |  Quote  |  Print  |  Notify Moderator
The pin is there on a very good reason.....to keep the adjustable nut in position...and yes they can back off without a pin destroying the bearings/axle stub/hub over time. I've seen this happen on trailers in commercial service. RV trailers would be no different as all the axles are the same brands.
Trailer axles use different size cotter pins depending on axle brand and axle size.
Westcoasting
westcoast
Posted: 03/17/19 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
I always use them till the bitter end! Exactly what you said about it doesn't take much at all to hold the nut.
GrandpaKip
Flat Rock
Posted: 03/18/19 07:46am Link  |  Quote  |  Print  |  Notify Moderator
I have reused cotter keys on boats and trailers as long as I can remember. Unless it has been work hardened to the breaking point or so bent up it’s hard to get through, I have never seen a reason not to reuse one.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
 > Cotter pin size?
