RV.Net Open Roads Forum: Fifth-Wheels: LM SAVANNAH ACTUAL PIN WEIGHT
 > LM SAVANNAH ACTUAL PIN WEIGHT
Allworth
Orlando, FL
Posted: 03/17/19 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
If you have to ask, you don't have enough truck!
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
alboy
Kelowna B.C.
Posted: 03/17/19 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
I knew it would be tight for a SRW ,waiting on Travelling man to get back to me as he has the identical rig,wife is not excited to drive a dually ,im fine with it.
kaydeejay
SE Michigan, USA
Posted: 03/17/19 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
You are in BC? I believe that is about the only jurisdiction where exceeding truck GVWR is ticketable.
BC RV and Towing regs.
Get a dually!!
Keith J.
Sold the fiver and looking for a DP, but not in any hurry right now.
alboy
Kelowna B.C.
Posted: 03/17/19 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
Yes ,will start looking for a truck with training wheels,yes they will go after you here,been there.
thanks
laknox
Arizona
Posted: 03/19/19 10:16am Link  |  Quote  |  Print  |  Notify Moderator
Travlingman wrote:
I have a 2014 Landmark Savannah and have a 3800 LB. pin, and this is with a loaded weight of 15,580 lbs.
So, a =weighed= pin ratio of 24.3%. At GVW, that's right at 3,950 lbs. Personally, I might do it, but I'd have =everything= in the FW, and nothing but full fuel and the DW in the truck.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
alboy
Kelowna B.C.
Posted: 03/19/19 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
YES AND NO water in the tanks,thinking Dually then i dont have to think about it anymore
justme
Posted: 03/19/19 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
Well I don't know about the LM Savana, but I seen a 2015 F250 diesel SRW pulling a Mobile Suites that has a GVW of 20K. I assume that TV had air bags because it was sitting level. I am certain that TV was well beyond Ford's specs and seem to be doing well pulling that trailer.
If the F250 and F350 dually have the same frame and same axles with the only difference is more tires on a dually, I don't see problem if the F250 has the tires rated at the load with air bags supporting the extra load.
* This post was last edited 03/19/19 02:04pm by justme *   View edit history
Cummins12V98
on the road
Posted: 03/19/19 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
HEY, bags and 19.5's YA can tow ANYTHING!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
kaydeejay
SE Michigan, USA
Posted: 03/19/19 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
Not in British Columbia you can't!!! [emoticon]
alboy
Kelowna B.C.
Posted: 03/28/19 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
Dually UPDATE!!
Bought a 2015 Ram Dually asin/385/900/14000gvw/rear air suspension/Laramie/premium leather upgrade,lovely condition.
Wifes happy,im happy .
Thanks guys/gals Happy travelling
