RV.Net Open Roads Forum: Beginning RVing: Oil Change
 > Oil Change
Page of 5
david1601
Foley, AL
Posted: 03/17/19 08:32am Link  |  Quote  |  Print  |  Notify Moderator
Kinda new to the cross country RVing. We are leaving May 2nd for 3 & 1/2 months on a trip to the west coast and back across Canada. It will be around 9,000 miles total. My question is about getting the oil changed in a 36' gas RV that is 12' tall.
What are the best places do this? Truck stops, dealerships? Or do you do it yourself and if so, how do you dispose of the old oil properly? At home I do this myself but have no idea about on the road.
Thanks.
2018 Tiffin 34PA
2018 Jeep Cherokee Trailblazer
David & Ellen
Foley AL
VoodooMedicineMan
Illinois
Posted: 03/17/19 08:38am Link  |  Quote  |  Print  |  Notify Moderator
Look for a pit at Walmart. They go under without lifting the rv. They're not at all of the service depts but if you ask they will know.
Bill and Joey the dog
js218
on the road
Posted: 03/17/19 08:52am Link  |  Quote  |  Print  |  Notify Moderator
I've used truck stops and large truck repair shops no problem.
2017 Haulmark 45' Super C 600hp, 12 speed I shift transmission, tandem drive axles, 3 stage engine brake, towing 26' trailer with an 08 explorer inside.
Jim
pianotuna
Regina, SK, Canada
Posted: 03/17/19 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Places such as Great Canadian Oil Change. But bring your own oil--much much much cheaper.
Regards, Don
esyers
NJ
Posted: 03/17/19 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Some Walmarts have a bay high enough. Walmart also accepts used oil if you change it yourself.
IB853347201
Eastern Ontario
Posted: 03/17/19 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Often you can get a mobile mechanic to come to your campsite and do for you. Just google "mobile mechanic" when you decide it's time. Usually they are very reasonably priced.
Touring in our 2010 Suncruiser, beaches, site seeing, national parks, chillaxing..
time2roll
Posted: 03/17/19 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
10,000 miles? I would just top it off as needed and keep rollin'.
675w Solar pictures back up
John Wayne
Long Beach, Ca
Posted: 03/17/19 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Get the valve that replaces the drain plug the one with a nipple to attach a plastic drain tube. Get one or two empty jugs. Drain the oil into the jugs. Take a large freezer bag put it over the oil filter unscrew the filter the oil will drain into the bag. Drain the bag into one of the jugs and toss the bag and filter. Fill with new oil. Take the jugs to an auto parts store. You're done.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
BarneyS
S.E. Lower Michigan
Posted: 03/17/19 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
My advice would be to use a mobile RV maintenance service once you reach your halfway destination. We used one just like this one several years ago while we were in Texas and were completely satisfied. They come to your location and change oil, grease, etc. with very reasonable prices. Often, you can inquire at the campground office and, if they allow it, will have a recommendation of a good place to call.
Barney
Not towing now.
azrving
Oatman
Posted: 03/17/19 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
I have a fumoto valve on my CTD which let's me dump directly into the empty gallon jugs that I bring along. I hold a plastic garbage bag over the filter while I remove it and then take the jugs to a place like O'Reilly's.
Draining the filter on to firewood makes greater fire starter.
Page of 5
 > Oil Change
