RV.Net Open Roads Forum: Fifth-Wheels: Water hose
 > Water hose
Cummins12V98
on the road
Posted: 03/18/19 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
I purchased the 90 brass fitting from them also.
Also purchased the 60psi adjustable WATTS regulator from them with the fittings included.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ford truck guy
Pennsylvania
Posted: 03/18/19 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
I already have the Watts saved into my cart on their site, just was not sure about the hoses...
My Watts that I use now has an issue with the screen, I forgot to remove it for the winter and it froze ... darn me...
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
JTrac
Oklahoma
Posted: 03/18/19 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
Whoever said Zero G is spot on. I've had mine for several years and used it when camping in freezing weather. We unhook it, of course, when the temps are going below 32. As long as you don't let water freeze in it it will roll up, or fold up if you prefer, just as well as it does in warm weather. The neat thing is it takes up very little space. I had to order my 25' rv type but Lowe's has a 50' version that is drinking water safe. I have both.
JimT
2013 Excel Winslow 34RKM, 2020 Ford F350, Platinum, 6.7 diesel, 4X4, CCLB, SRW, 12,400 GVWR
chiefneon
Livingston, TX
Posted: 03/18/19 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Howdy!
I have also been using Zero G hose for years now and I ‘m very pleased with it. I carry a couple of 25 footers.
“Happy Trails”
C
Cummins12V98
on the road
Posted: 03/18/19 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Forget but the gauge is filled with something special type of liquid.
I went with the brass ends, they are HD.
buc1980
houston tx
Posted: 03/19/19 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Flexzila hose got a lot of bad reviews.
2017 Ford F350 DRW,2005 Kountry Star 35ft,14750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.
Rvpapa
Alberta , Can.
Posted: 03/19/19 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
Stupid as it sounds, this really works https://www.amazon.com/s?k=stainless+steel+water+hose&crid=12XKFQMKXESC7&sprefix=stainless+steel+water++h%2Caps%2C260&ref=nb_sb_ss_i_1_23 .
Made like BX cable and has a very flexible (possibly silicon)liner.
Will hand coil easily in a 12 inch diameter coil. Personally used at +5F.
Art.
ependydad
Here and there
Posted: 03/19/19 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
Check with RV Water Filter Store, they might be able to replace just the gauge. I had to do that a few years ago. In fact, I could probably do it again- mine is showing way low (like 20psi) when I know the pressure is higher. If I recall, it was something like $20-25.
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
ford truck guy
Pennsylvania
Posted: 03/19/19 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Gonna try that... It's on my to-do list for now....[emoticon]
Cummins12V98
on the road
Posted: 03/19/19 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
The hose ends are very heavy duty, not stamped brass. Gauge is liquid filled that won't freeze.
 > Water hose
