RV.Net Open Roads Forum: Towing: Lubing my Reese Strait_Line hitch w/Dual Cam
Search only in Towing
Open Roads Forum  >  Towing
 > Lubing my Reese Strait_Line hitch w/Dual Cam
Bobbo
Wherever I park
Posted: 03/19/19 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Whenever I hook up my TT, I grease the ball before putting the coupler on it. I grease the hinge pins on the torsion bar arms before putting them in the hitch head. Should I be greasing the underside of the torsion bar arms where they sit on the Dual Cam arms?
Bobbo, Linda and the furry kid (45 pound rescue)
mooky stinks
Cicero,NY
Posted: 03/19/19 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Not with grease. I believe the instructions say that you can use a small amount of Vaseline to keep the noise down, but do not use grease.
2017 Silverado 1500 LT, Max Tow
2012 Outback 277RL
DustyR
Posted: 03/20/19 05:27am Link  |  Quote  |  Print  |  Notify Moderator
X-2
Coachmen Denali 270FK 32 Ft.
Tow Vehicle: 2008 Silverado 2500 HD
Duramax, Allison Transmission,
EFI by Kory, 4" Exhaust w/muffler turbo back
BarneyS
S.E. Lower Michigan
Posted: 03/20/19 07:58am Link  |  Quote  |  Print  |  Notify Moderator
You can, as already mentioned, put a small amount of Vasoline on the cams to reduce any noise or excess wear, but that should not be necessary on the size/weight of the trailer in you signature. Using Vasoline is supposed to be for very heavy tongue weight trailers and primarily to reduce wear on the cams.
Mine, for instance, is over 1300lbs and I did use Vasoliine on the cams when I used the Dual Cam hitch many years ago. Didn't have to put it on very often. If I recall correctly it was only necessary a couple of time per season.
You are doing the right thing greasing where you mentioned but if you do use the Vasoline, just put it on the cam itself and not on the spring bars. Using Vasoline will not reduce the amount of sway control like grease would but does reduce the wear and noise. I had none with mine.
Barney
2019 Ram Limited 1500, 5.7L Hemi, 4x4, SB
Not towing now.
dodge guy
Bartlett IL
Posted: 03/20/19 10:33am Link  |  Quote  |  Print  |  Notify Moderator
You only grease the cams when there is more than 1200lbs. I forget the terminology but it says something like “do not use grease, ise vaselinne only. I’m certain instances with higher tongue weights a very light coating of grease can be used to decrease excessive wear!” It’s in the owners manual.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Bobbo
Wherever I park
Posted: 03/20/19 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all. I will just keep on doing as I have been doing.
Hannibal
Tampa Bay Area
Posted: 03/22/19 05:46am Link  |  Quote  |  Print  |  Notify Moderator
I put just a dab of marine grease on the L brackets of my Equalizer 4 point. I can’t tell the difference from the driver’s seat except that it’s quiet. If it were me, with your trailer, properly loaded and hitched, I would do the same for the same reason. Not a recommendation nor am I telling anyone else what to do. Just stating what I do and would do.
'10 F250 XLT CC SB 5.4L 5spdTS 3.73 103k miles
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'. Reese HP Trunnion 800
mosseater
Dillsburg, PA
Posted: 03/22/19 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
I've used a dab of Vasoline on my cams since new. Tongue weight runs around 1050 */-. I have not seen any issues with control. Really helps quiet it down. I also shoot a little penetrating spray on the snap chains. As the bars shift, the links can pop and groan a little. Mine doesn't make a peep.
Sunset Creek 298 BH
JBarca
Radnor, Ohio, USA
Posted: 03/30/19 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
I'll add a little to hopefully help the cause.
Reese changes their instructions from time to time, and I must admit the instructions of today are a lot better than years ago.
See here for the current issue as of this post from the Reese Products site. These are dated 5/31/2017 Rev T. http://www.reeseprod.com/support/installation/N26002.pdf
On page 9 of 33 they state:
Reese Products wrote:
MAINTENANCE:
1. DO NOT – use grease on the cams or cam arms.
2. If noise of the system is offensive, a very light coating of lubricant such as Vaseline may be used on the portion of the cam where the spring bar rides on the cam. Tongue weights in excess of 1,200 lbs. may require the use of such a lubricant to prevent excessive wear.
3. Keep all painted parts painted to prevent rust and maintain a good appearance. (Do Not paint over labels
Reading the words as written, if noise is offensive, you can use a light coat of Vaseline to tame down the noise. It really does not state what TW needs the noise reduction. On loaded tongue weights of over 1,200#, Vaseline may be used to reduce excessive wear as now stated. However it does not declare what excessive wear really is. Years ago (pre 2006), 1,200# WD bars were the largest they ever made and using vaseline was OK back then when used on 1,000# TW's.
Years ago, they would describe the vaseline as a weak lubricant in their instructions and it was OK to use on the cams as it not considered an actual grease in their mind.
I have been using the Reese DC on several different trailers for the last 15 years. On our large camper, I have one pair of DC's that have over 50,000 miles on the original set. While the spring bars changed size from camper to camper, I kept using the same cam arms and cams.
I found these things out which are not mentioned in the lastest instructions.
When the cams are brand new, you will notice a lot of metal wear, (metal chips dust) on the cams. This is normal. This wear is the WD bar wearing off the contact spots on the cam arms. As mileage increases, the wearing dust slows down as the contact patch of wear on the cam is larger.
The WD bars and the latest new DC lobes are not machined. The WD bars are forged and DC is cast steel. The older DC had machined cam lobes but the WD bars have been forged. The lengths of the WD bars are not exact nor the cast steel DC lobes.
I have found that you should mark the WD bars left and right once the DC is adjusted spot on perfectly centered in the WD bar V. Then always use that same WD bar on the same side going forward. The WD bar and the cam over time become a worn in matched set. The contact patch on the DC matches the wear pattern on the WD bar. If you do not use the same WD bar on the same side all the time, that contact patch wear will start all over again because you flipped the bars around from side to side. And that flip flopping can create higher wear then leaving them on the same side.
My tongue weights on the original cams have varied from 1,000# to 1,600# across a few campers. The current camper we have had since 2007 has 1,700# WD bars on it with a 1,600# loaded TW. I do use the vaseline for wear and it tames the noise. As BarneyS stated, I do not reapply every trip. The Vaseline is good for many trips. When you start seeing new metal wearing (metal chip dust) or hearing the grinding, then it is time to put another light coat on. In time, you will know when to add.
I have a smaller camper also with a 800# TW using the new cast steel DC and 800# bars and I do not use the vaseline. It is not really needed on this lighter setup.
The vaseline will reduce the friction of the DC. It has to in order to reduce the wear. However, a light film of it "normally" will not affect the anti sway. But, a larger quantity can reduce the sway control a small amount pending other factors in your truck setup. You really do not need much lube to tame down the noise and wear.
Hope this helps
John
* This post was edited 03/30/19 10:28pm by JBarca *
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
Bobbo
Wherever I park
Posted: 03/31/19 07:27am Link  |  Quote  |  Print  |  Notify Moderator
Thank you JBarca, that is very informative.
