RV.Net Open Roads Forum: Travel Trailers: Time to Buy New Tires
 > Time to Buy New Tires
Page of 5
Huntindog
Phoenix AZ
Posted: 03/21/19 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Gulfcoast wrote:
They put 205 75 14 on my trailer, had they wanted something else on the trailer, they would have put them.
My trailer has a sticker with the recommended tire size.
One word::::::: COST!
Your manufacturer wanted you to have the LOWEST COST tires..... So they could make more profit.
If there were a tire that cost .50 less. that is what they would want it to have. The same goes for just about everything that your TT is made of. Most RVs have a lot of "BLING". Things that look great on the dealers lot, but cost little and add nothing to actual performance.... Yet impress potential buyers...... While things that really matter like frames, axles, tires, etc. get shortchanged.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2020 Silverado High Country CC DA 4X4 Big Dually.
trailer_newbe
Tucson
Posted: 03/21/19 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
Goodyear, done.
2018 Jayco White Hawk 28RL
owenssailor
Ontario
Posted: 03/21/19 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
Just put on Goodyear Endurance - same size as yours. They are D rating and also rated for 87 MPH. Much better than the original tires. I now have much higher weight carrying capacity and a much higher speed tolerance since I only tow at 62 - 65
2011 Jayco 28U
2012 Chev Silverado Crew Cab 5.3 6 spd 3.42 (sold)
2017 Chev Silverado Crew Cab 5.3 8 spd 3.42
Equal-i-Zer 1400/14000
RotoChocks
bob213
Fresno, CA
Posted: 03/21/19 11:29pm Link  |  Quote  |  Print  |  Notify Moderator
If your rims can handle 65 psi then the Goodyear Endurance. If not, Maxxis.
215 is fine if you have the clearance for them but I don't really think you gain much. Many people like the new Carlisle but I think the "new part" of the tire only comes in larger sizes.
It's cheaper to buy good tires than to repair what cheap tires have damaged.
CALandLIN
SC
Posted: 03/21/19 11:55pm Link  |  Quote  |  Print  |  Notify Moderator
trail-explorer wrote:
Gulfcoast wrote:
I'm keeping the size that Jayco wanted me to have.
Never heard of an RV manufacturer dictating to customers what size tires "they should have"
Read your owner's manual, it's in there.
CALandLIN
SC
Posted: 03/22/19 12:03am Link  |  Quote  |  Print  |  Notify Moderator
rfloyd99 wrote:
I need new tires on my Jay Feather 26' TT. It weighs about 6,000 lbs loaded. Original tires are ST205/75/R14 6PR LR C (max load single 1760 lbs)
I've read several tire threads here, and still have some questions. Of course, I want to spend as little as I can but still get good quality. I put 19,000 miles on the original tires in three years, and plan to put on 5 to 7,000 miles each year. So, quite a bit of use.
Questions:
1. Seems like I can get C or D rated tires for not much price difference - should I definitely get one or the other? There seem to be more choices in the C rating.
2. Most are 6 ply, a few 8 ply. Again, is one a clear choice?
3. I see a few good choices that are 215 vs 205. Can I go up to 215 with the rims I have, and are there any advantages?
4. Any thoughts on price range/brands? Seems like I can get Greenball Transmaster D/8ply from Walmart for $49 ea, or Carlisle C or D or Maxxis C for about $85, or Goodyear Endurance D for $103.
Anybody care to answer/opine on these questions? Any help will be greatly appreciated!
There is a basic minimum industry wide standard for replacement tires; they must provide a load capacity equal to what the Original Equipment tires provided.
LarryJM
NoVa
Posted: 03/22/19 12:36am Link  |  Quote  |  Print  |  Notify Moderator
Look at your FMVSS tire load label and the recommended size tire size is right there and is what the manufacturer supplied as OEM.
Larry
RAINKAP INSTALL////ETERNABOND INSTALL
2112
Posted: 03/22/19 05:33am Link  |  Quote  |  Print  |  Notify Moderator
I went through this same exercise last year and bought the Goodyear Endurance for a piece of mind. They are WELL within their load limit, I can speed up to 70-75mpg to pass slower vehicles if needed without worrying about my tires, and pot holes are less of a concern now but I still don't like hitting them. To me, that piece of mind was worth the extra money.
You plan on traveling 7000 miles/yr. Think about it.
2013 KZ Durango 2857
DustyR
Posted: 03/22/19 05:56am Link  |  Quote  |  Print  |  Notify Moderator
SoundGuy wrote:
Just buy a set of Goodyear Endurance tires which in your size will be LR D and be done with it. [emoticon]
X-2
I went with Goodyear Endurance. I had considered Carlisle or Hercules. The Endurance is pricey, but have a good record.
Coachmen Denali 270FK 32 Ft.
Tow Vehicle: 2008 Silverado 2500 HD
Duramax, Allison Transmission.
Iraqvet05
Greenwood, MO
Posted: 03/22/19 06:12am Link  |  Quote  |  Print  |  Notify Moderator
When I bought Maxxis tires for our old TT, the Goodyear Endurance was only offered in a load range D. You can run LR D if your rim can handle the pressure. I tried to identify the manufacturer and model of the rim and I ran out of time before a long trip to Colorado so I just stayed with LR C tires.
2017 Ford F-250 6.2 gas
2018 Jayco 28BHBE
US Army veteran
Page of 5
