RV.Net Open Roads Forum: Travel Trailers: Time to Buy New Tires
 > Time to Buy New Tires
Page of 5
rfloyd99
Posted: 03/21/19 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
I need new tires on my Jay Feather 26' TT. It weighs about 6,000 lbs loaded. Original tires are ST205/75/R14 6PR LR C (max load single 1760 lbs)
I've read several tire threads here, and still have some questions. Of course, I want to spend as little as I can but still get good quality. I put 19,000 miles on the original tires in three years, and plan to put on 5 to 7,000 miles each year. So, quite a bit of use.
Questions:
1. Seems like I can get C or D rated tires for not much price difference - should I definitely get one or the other? There seem to be more choices in the C rating.
2. Most are 6 ply, a few 8 ply. Again, is one a clear choice?
3. I see a few good choices that are 215 vs 205. Can I go up to 215 with the rims I have, and are there any advantages?
4. Any thoughts on price range/brands? Seems like I can get Greenball Transmaster D/8ply from Walmart for $49 ea, or Carlisle C or D or Maxxis C for about $85, or Goodyear Endurance D for $103.
Anybody care to answer/opine on these questions? Any help will be greatly appreciated!
Gulfcoast
Alabama
Posted: 03/21/19 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
I have Goodyear Endurance... 205 75 14 on my Jayco.
I'm keeping the size that Jayco wanted me to have.
I trust the Goodyear Endurance tires that are made in AL and NC.
SoundGuy
S Ontario
Posted: 03/21/19 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Just buy a set of Goodyear Endurance tires which in your size will be LR D and be done with it. [emoticon]
2012 Silverado 1500 Crew Cab
2014 Coachmen Freedom Express 192RBS
2003 Fleetwood Yuma * 2008 K-Z Spree 240BH-LX
2007 TrailCruiser C21RBH * 2000 Fleetwood Santa Fe
1998 Jayco 10UD * 1969 Coleman CT380
trail-explorer
NM
Posted: 03/21/19 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
Goodyear Endurance.
Bob
trail-explorer
NM
Posted: 03/21/19 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
Never heard of an RV manufacturer dictating to customers what size tires "they should have"
Gulfcoast
Alabama
Posted: 03/21/19 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
They put 205 75 14 on my trailer, had they wanted something else on the trailer, they would have put them.
My trailer has a sticker with the recommended tire size.
* This post was edited 03/21/19 03:35pm by Gulfcoast *
Gulfcoast
Alabama
Posted: 03/21/19 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
If I may say one more thing without someone jumping on me...
Even cheaper tires would work for me, with a good TPMS to keep a check on them.
colliehauler
Mc Pherson KS USA
Posted: 03/21/19 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Another vote for Goodyear Endurance. I seen the damage a cheap tire can do to a RV without wheel wells.
JIMNLIN
Oklahoma
Posted: 03/21/19 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
1. Depends on the trailers GAWR and GVWR and actual load on the axles. All need to be considered.
2. no but much depends on answers to #1 answers.
3. IMO as long as the larger tire has clearance in the wheel well a next size up can be a good upgrade.
4. The Greenball have the most tire complaints on NHTSA/dot.gov website.
..Carlisle makes several line of trailer tires. The only one I would choose is their new Carlisle HD.
..Maxxis has a checkered history of failures over the years and still 65 mph rated. Most other are 75-81 mph rated. Speed rating are more to do with a tire ability to deal with heat as our load carrying tires on our trailer are subjected to.
...Goodyear Endurance is a new gen ST tire out about two years now. So far very few if any reliability complaints and a good tire for the money.
If your trailers sits 11 months out of a year and makes short local runs then cheap tires may be for you. If the trailer is on the highway at interstate speed then IMO a better tire is worth the money.
Were not required by any law to use the same size tire as the trailer mfg picked. Your only requirement when replacement comes around is...... the sum of the maximum load ratings of the tires fitted to an axle shall be not less than the gross axle weight rating (GAWR) of the axle system as specified on the vehicle's certification label.
NWnative
Queen Creek, AZ
Posted: 03/21/19 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Goodyear Endurance. If you can get a Load Range D then you should consider it. The extra margin for weight carrying would be a benefit.
2019 Ford F250 Lariat CrewCab Short Bed 4x4 - 6.2 Gas w/4.30 Axle
2016 Airstream Flying Cloud 30RB / Blue Ox Sway Pro / Rock Tamers
2017 Jeep Grand Cherokee Limited 4x4
Page of 5
