RV.Net Open Roads Forum: Fifth-Wheels: 6 Point Self-Leveling Systems
 > 6 Point Self-Leveling Systems
klr650goldwing
minnesota
Posted: 03/21/19 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
Wondering if these new 6 Pt. Leveling systems make the 5er more stable? Can you lift the entire 5er off the ground? Do 5ers with this system still jiggle as a person walks around inside? Is there a down side to these systems?
2014 Grand Design Solitude 369RL
2017 F350 6.7 DRW CC LB 4X4
2012 Mercedes E550
2010 Honda Civic
2009 Saab 93 Aero Convertible
2004 Honda Goldwing GL1800
2004 Kawasaki KLR650
1966 Honda 305 Dream
SDcampowneroperator
South Dakota
Posted: 03/21/19 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Yes somewhat
Yes should you?
Yes a little better. Downside? yes they can leak off Get out of calibration. Add weight and compexity. And $$$
jtaylor1920
Oregon
Posted: 03/21/19 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I think so.
You can, but Lippert says not to do it. I’ve done it when I put on my Moryde 4000 and wet bolt kit and would use it to change a flat if needed.
Yes, we still have some movement.
I haven’t found one yet, and I wouldn’t buy another rig without it.
John, Laurie & the 2 Schnauzers (Mazie & Obi)
2016 GMC Duramax Dually
2018 Cardinal 3350RLX
B&W Companion Hitch
Edd505
Elephant Butte, NM
Posted: 03/21/19 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I think so.
I haven’t found one yet, and I wouldn’t by another rig without it.
Exactly as I have found on mine after 2 years, I won't buy another without it. Yes they do lose calibration, zero point in their language. Easy to reset just follow the manual. I think I have done it 2 or 3 times in the two years and I use my 5W traveling about 9 months a year.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
Campinghoss@51
Windsor NC
Posted: 03/22/19 04:51am Link  |  Quote  |  Print  |  Notify Moderator
As long as the 6 point system comes with JT strong arms then yes they are good and virtually eliminate the jiggles as you call it. I would not use mine to lift the fiver off the ground except in an emergency situation and then be cautious.
Camping Hoss
2017 Open Range 3X 388RKS
2017 F-350 6.7 with hips 8'bed
Lucky & Lucie
Toolguy5
Columbia Station, Ohio
Posted: 03/22/19 06:01am Link  |  Quote  |  Print  |  Notify Moderator
We have it on our 5er and we have very little movement. This is the first unit we had with a leveling system. It is electric and not hydraulic.
Dan & Patty
Miss Pickles the Pomeranian Princess
2020 GMC 3500 Sierra Denali 6.6 Duramax / Allison tranny
2018 Jayco Northpoint 387 RDFS
BWRVK 3710 companion
Maddy the Pampered Pom @ Rainbow Bridge 12-3-2013
ChuckSteed
Mtn Home, Idaho
Posted: 03/22/19 06:46am Link  |  Quote  |  Print  |  Notify Moderator
The six point leveling system is not really new... it’s been out now for many years.. I have and like the hydraulic system over the electric system...
Use blocks under the pads t9 shorten the amount of leg extensi9n for a more stable RV...
After own8ng several RVs without sis point leveling I wouldn’t buy another without it..and it would be Hydraulic.
laknox
Arizona
Posted: 03/22/19 10:17am Link  |  Quote  |  Print  |  Notify Moderator
We have a 4-point on our KZ and love it. We also have factory JTs. The difference between our old Komfort, with old-style stabilizers and the 4-point, by itself, is amazing. I've forgotten to snug up the JTs a couple times and it took a while before I noticed. Once I did, the FW's as rock-solid as you could expect, short of putting a dozen jack stands under the frame.
Yes, you can lift the entire rig off the ground. Our system lifts the curb-side wheels off every time I part it in front of our house. Given that each jack will lift about 75% of the weight of the entire rig at GVW, I have zero issues with lifting one side if I needed to change a tire. In an extreme, I'd lift my entire rig, but block it on the frame for security. Our system is all-electric, so have no issues with leak-down like a hydro system could.
Yes, you can still feel some movement in our rig but, as I said above, the difference with our old FW is so great that we almost don't notice it. The JTs just make it even better.
Downside in our system is that the rear jacks only have about 8 or 10" of travel, so it's easy to run out on uneven ground. This is why my rig lifts the curb tires off the ground; slight slope to the rear and the crown in the road. I have to add a piece of cut off glue-lam under the right rear jack to prevent this. Another con is that it's and LCI product, so... That being said, I doubt I'll have another RV without auto-level =or= JT Strongarms! [emoticon]
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
klr650goldwing
minnesota
Posted: 03/22/19 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone. This helps with some decisions we will be making soon.
ACZL
UPstate,NY
Posted: 03/23/19 08:06am Link  |  Quote  |  Print  |  Notify Moderator
New coach came w/ them and we love them....6 pt level up. Beats having to place boards under wheels. A lot more stable than just front legs and rear stabs. Still have a lil wiggle, but doable. Have lifted the whole coach or all tires off the ground w/o a problem. One criteria the DW had was that we get the 6 pt on the next coach. We place blocking under the legs to lessen the gap between pad and ground. Takes longer to figure out how much to put under each leg than to level it. Once you hit Auto-Level, it's like <2 minutes and she's done.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
