RV.Net Open Roads Forum: Beginning RVing: What length sewer hose?
 > What length sewer hose?
Airdaile
On The Road
Posted: 03/22/19 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
You could also move your rig closer to the sewer tap.
grampachet
West Coast
Posted: 03/22/19 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
I have used the Sewer Solution now for 10 years. Very satisfied with this simple solution to dumping the tanks. I use a 15’ flexible 1” diameter hose with 30 feet of 1” pvc in 5’ lengths with slip joint couplings in lengths. If I need a long run I just slip the needed pieces together with a piece of duct tape to make sure they don’t disconnect. Never any leakages and can discharge up to 3’+ uphill in a 30’ + run. Makes a nicer cleaner work then the stinky slinky.
2004 F-250 KIngRanch,CC,SB,SRW,4x4,V-10,3.73
2008 Montana 3000RK
JKJavelin
Milwaukee, WI
Posted: 03/22/19 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
I've got 2 of the 20 foot kits. Most of the time I only need a 10 foot section, but I've had to use 30 feet of hose twice so far.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS--Now with Titan Disc Brakes
Morryde SRE-4000 w/ wetbolt kit
Demco Hijacker Autoslide 18k
2017- 21 Nights
2018- 75 Nights
2019- 67 Nights
STBRetired
I-80 and I-55
Posted: 03/22/19 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have the 15 foot and the 20 foot kit. I have had to use all 35 feet in a couple of sites. Lets me make ou connection of 10, 15, 20, 25, and 35 feet. Have had the RhinoFlex hoses for 4 years and very satisfied with them.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
1320Fastback
Vista, Ca
Posted: 03/22/19 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
Up until last weekend at a dog show in Louisville a 15' slinky hose has been all I've needed. We were one of thousands of RVs and had a dedicated spot but the sewer was a good 30' away. Moving was not a option as every single spot was reserved with trailers inbound from all over the country and arriving by the minute.
I went to the local Walmart and bought four 10' sections and now have them when ever I need them again. They each came with clamp on caps for when not in use and a 90° elbow for the sewer connection not that I need three of those.
In the end we can all recommend this length or that but there will be a time when it won't work [emoticon]
1992 D250 Cummins, 5spd, 4"' straight piped, sensors deleted, airbags, DAP injectors, 18cm.
stickdog
Somewhere, USA
Posted: 03/22/19 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
Two 10 ft work 99% of the time though we have had longer runs to contend with so we carry extra two 10fters but they're still in the box.
9-11 WE WILL NEVER FORGET!
17 MS 36 RSSB3
Gone 04 HH DA LS 33.5 RLTG
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
ROBERTSUNRUS
Salem, Oregon
Posted: 03/22/19 11:20pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon] Hi, I bought the Dominator sewer hose kit with two 10' hoses. While driveway camping at a friends house, I needed 45' of hose. So I bought three more 10' hoses. At 95% of the camp grounds, all I need is one 10' hose. I like the Dominator hoses because they collapse down to 3' each.
"> Bob ">
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
hondapro
Central Pa
Posted: 03/23/19 05:31am Link  |  Quote  |  Print  |  Notify Moderator
I use two 10 foot sections but I also carry two more 10 foot sections that are still in the box. I also carry a extra 50 foot of the white water hose.
Steve
2016 F-350 6.7 Diesel
2015 Springdale 311RE
Wherever I happen to park
Posted: 03/23/19 06:56am Link  |  Quote  |  Print  |  Notify Moderator
Depending on where I park I've used the hose that came with the RIG (about 10' as I recall) a 5 foot extension hose. 10-15-20 and currently 25 foot. The 25 Foot is a "Sentinel" by I think Tetford and frankly I like it better than I Did the Rhino flex jobs it replaced.
Home is where I park it.
BeerBrewer
Long Island
Posted: 03/23/19 11:44am Link  |  Quote  |  Print  |  Notify Moderator
Should I also invest in a sewer support? I was also thinking of buying the 30 ft Sidewinder hose support. It seems like it would work at almost any length up to 30 ft...yes?
