RV.Net Open Roads Forum: Tow Vehicles: Integrated brake controllers
Search only in Tow Vehicles
 > Integrated brake controllers
Sportsmen
Houston, Texas, USA
Posted: 03/25/19 07:42am Link  |  Quote  |  Print  |  Notify Moderator
I am trying to understand how the integrated brake controller works on my new to me 2016 F250. On my old truck I had a Draw Tite after market controller. I could jack up one side of the trailer, throw a tool box against the brake pedal and see if each wheel on the trailer locked up. No problem. Using this procedure I have discovered brake problems on individual wheels before heading out on trips.
On my 2016 if I manually operate the brakes using the dash mounted control the brakes will lock up. If I depress the brake pedal (truck running in Park) I have no trailer brakes. Per the owners manual the braking is reduced to the trailer when the truck is travelling under 11 mph.
So, how do you test the brakes using the brake pedal BEFORE you hit the road ????????
Any insight is appreciated !
2016 Jayco Jay Flight 27BHS 6210 empty, 8200 GVW
2016 F250 CC 6.2L(gas) 3:73 diff (3157lb. payload)
mkirsch
Rochester, NY
Posted: 03/25/19 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Modern brake controllers sense acceleration/deceleration. No deceleration, no braking. Your old controller was likely a time delay style.
Use the dash mounted control to test the brakes. If you have brakes there, it's just a matter of adjusting the controller, and you can only do that on the road.
Retired JSO
Northeast Florida
Posted: 03/25/19 08:36am Link  |  Quote  |  Print  |  Notify Moderator
In addition to you having a Gain adjustment, newer Fords also have 3 effort settings on the dash trailer set up along with sway control. All covered in the manual.
Me Again
Sunbird(Wa)/snowbird(Az)
Me thinks the RAM trailer brake engineer that screwed up the RAM IBC starting with 2013 to 2015 time frame model years must have moved to FORD for the 2016 models.
shum02
Burlington ON CDA
Posted: 03/25/19 09:00am Link  |  Quote  |  Print  |  Notify Moderator
My '06 F350's integrated brake system works the same. I hit the manual control to test the brakes, not sure why that's a problem? Also had a Prodigy that worked the same.
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
philh
Belleville MI
Posted: 03/25/19 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Pull the brake cable on the trailer. That should lock up each wheel.
bpounds
Senile, er I mean
Posted: 03/25/19 10:06am Link  |  Quote  |  Print  |  Notify Moderator
The Ford controller doesn't send power to the brakes when you are moving less than about 10 MPH. I don't like it either, don't understand why they did that, but fortunately the levers on the controller still work even when stationary. Just have someone pinch them for you, or if you must work alone, a small woodworking spring clamp could be used.
As far as a pull test, that should always be done with the controller levers, not the service brake, so I don't get that part of your question. The point is to test the trailer brakes, not the truck service brakes.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Posted: 03/25/19 10:56am Link  |  Quote  |  Print  |  Notify Moderator
Hook it up and go for a little drive and see if they work? I can't imagine jacking up the trailer to test brakes pre-trip.
Agree diagnosing problems can be a bit more difficult and to date, I've had far more "service trailer brake messages" from a plethora of IBC equipped trucks in the last 10 years than ALL other add on brake controllers for the last 30 years. I've literally dealt with 100s if not 1000s of light duty trucks in some capacity from driver to mechanic and I don't look forward to when these newer trucks get old....I'll have to buy a nother new one, lol!
03 Arctic Fox 860
07 Dodge 2500 deezul
"Obviously I don't want to overload my truck and be unsafe, but the reality is the truck is way more capable than the 10K GVWR they put on the sticker.
KJ"
Bedlam
PNW
Posted: 03/25/19 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
This is the way I check my enclosed trailer brakes.
Checking the integrated controller and connection is a little tougher since it uses technology that defeats the old methods. You may be able to squeeze the controller paddle to verify signal is coming on the brake wire, but it may not output anything without a trailer connected and only limited voltage when not moving. Once you know that your trailer brakes actually work by pulling the pin, the best way to check the controller is to squeeze the paddle while driving at 30+ mph.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
Bedlam
PNW
Posted: 03/25/19 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
I check my brakes when jacked while rotating tires on my trailer. The trailer is already up and it quickly tells me if each brake is actually working. I rotate the tires once a year, so this method only gets used once a year unless I was having some type of problem.
