RV.Net Open Roads Forum: General RVing Issues: Generator quits
 > Generator quits
georgelesley
Tennessee
Posted: 04/10/19 07:54am Link  |  Quote  |  Print  |  Notify Moderator
Problem solved for real this time! Onan called this morning. They kept it overnite at my insistence after a day of fruitless searching. This morning it finally stopped when a mechanic started it and would not restart. He tapped the fuel pump with a wrench and it restarted and ran fine. The pump is on order. Yea!!
George & Lesley
2014 Itasca Sunova 33C, 2019 Jeep Cherokee Lattitude Plus toad, Demco/SMI towing system
doxiemom11
Paris, MI
Posted: 04/10/19 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
We are currently having the same issues with our Onan. This thread has been very helpful. Probably the same problem.
georgelesley
Tennessee
Posted: 04/11/19 05:23am Link  |  Quote  |  Print  |  Notify Moderator
Good luck with yours and let us know the result.
BTW, now I know far more about generator engines than I ever wanted to know, I suggest if your symptoms are similiar to ours, obviously check the fuel pump, but also the shut off solenoid on the carb float bowl.
D.E.Bishop
Eagle Rock, CA
Posted: 04/11/19 06:50am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for posting the solution George.[emoticon] It's always nice to add one or more items to the list of solutions.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
Back to a 2006 Suzi GV
Roadmaster 5000
Roadmaster backplates
 > Generator quits
