RV.Net Open Roads Forum: General RVing Issues: EZUP Canopy - Truss Repair
 > EZUP Canopy - Truss Repair
D.E.Bishop
Eagle Rock, CA
Posted: 04/11/19 07:02am Link  |  Quote  |  Print  |  Notify Moderator
My DD bought an EZ-up specifically because of other folks having them and their ease of up and down for one person. Being a nice person she loaned hers to a friend who broke a truss arm. It was never fixed and because we have no trees that shade my outside work area and the temps were in the 90's and 100's, I borrowed it to work on the DW's car and found the broken part.
Not having time to order and install an arm, I used some scrap red oak and fashioned a filler for the tube, it fit so tight no screws were necessary. She was suppose to look up, find and order a couple of arms so I could fix it properly. Needless to say she was too busy and never ordered the part, after all, DOD(Dear Old Dad) McGivered it and it works great, so let's just leave it.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
95 Suzuki Sidekick 4X4
Stowmaster 5000
Bobbo
Wherever I park
Posted: 04/11/19 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Sometimes the sentimental value overrides. When I was 16 years old, and in high school, I was on the JROTC drill team. I would practice at home with our 410 shotgun. One day, I dropped it and cracked the stock. At 16, my woodworking skills were non-existent. I fixed it by clamping it together, putting some finishing nails in to hold it, and wrapped it thoroughly in masking tape. DD announced one day that she wanted that shotgun. I told her fine, I will get a new stock for it. She said absolutely NOT. She only wanted it because of the cracked stock and the story behind it. (She already had a fully functional 410 of her own.)
Bobbo, Linda and the furry kid (45 pound rescue)
Kennedycamper
Algoa, Texas
Posted: 04/11/19 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
Go to the beach. People break these every day, and maybe you can find a part from a broken one.
RedLionCookie
Dallastown PA
Posted: 04/12/19 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
Update. The isn't actually and EZUP it was purchased through HOUZZ so it was an off brand. I contacted HOUZZ and several other sources with no luck. Most said the lengths and hole placements are very specific so it's not as simple as you might think.... according to them.
With that in mind I decided to try and fix what I had. The tubing for the trusses is obviously hollow. I decided to cut a piece of wood that would fit tightly inside the truss. The truss itself was actually 58 inches long. I cut the wood to be around 50 inches long. I was able to work the wood down through the truss and actually push out the dents and bends in the truss and get it back to its original shape. To finish it off I re drilled the center hole to connect the trusses and put a screw in each end to hold the wood in place. The whole process took me about an hour and I actually think it is stronger now than it was before! We will try it out this weekend but I'm confident it's going to work great!
Merrykalia
Appalachian (apple at chun) Mtn in the GREAT SW Va
Posted: 04/12/19 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
Over our 40+ years of camping, we have had several of these tents. We have found that the actual EZUP brand will last us in excess of 7-8 years, while the off brands will usually last 2-3 years. They are expensive, but well worth the money. We usually have an off-brand that we use here and there and if someone needs to borrow one, we will loan the off-brand.
2017 Ford F350 Crew Cab 6.7L 4x4 DRW
