RV.Net Open Roads Forum: Towing: torque for shank bolts
Search only in Towing
Open Roads Forum  >  Towing
 > torque for shank bolts
noonenosthis1
northern california
Posted: 04/02/19 12:39pm Link  |  Print  |  Notify Moderator
Hi all,
I've gone from an Excursion to an F350 for towing. The F350 is taller than the Ex so I've turned my hitch upside down and now I need to retorque the shank bolts. What is the correct torque for those bolts?
Thanks
rdhetrick
Posted: 04/02/19 01:10pm Link  |  Print  |  Notify Moderator
832.42729 somethings.
Ok, probably not.
Why not ask the manufacturer of the hitch?
Rob
2005/06 Mandalay 40E Full Time
2015 Jeep Grand Cherokee
TBammer
Mid-Michigan
Posted: 04/02/19 01:41pm Link  |  Print  |  Notify Moderator
Get the biggest breaker bar you can find for the socket that fits the bolt. Then get a 4 foot length of cheater pipe to go over the breaker bar. Then have your biggest/strongest friend lean on it until he can't lean no more. But my last reading was like 300-400 ft/lbs.
2016 Chevy 2500 HD, 6.0 gasser, 4.10 dif
2019 Arctic Fox 25W
Reese Pro-Series WD Hitch
jfkmk
NJ
Posted: 04/02/19 02:39pm Link  |  Print  |  Notify Moderator
Or you can take it some place where they actually use a torque wrench.
BarneyS
S.E. Lower Michigan
Posted: 04/02/19 03:24pm Link  |  Print  |  Notify Moderator
250 lb-ft for most manufacturers.
Barney
2019 Ram Limited 1500, 5.7L Hemi, 4x4, SB
Not towing now.
delwhjr
TX
Posted: 04/02/19 03:35pm Link  |  Print  |  Notify Moderator
If its an equal-i-zer the manual recommends 320 ft/lbs
2019 F250 Crew 4x4 6.2
2019 Rockwood UltraLite 2608BSD
BenK
SF BayArea
Posted: 04/02/19 04:02pm Link  |  Print  |  Notify Moderator
Standard is by ball shank dia, but best to check your ball's OEM specification
https://www.etrailer.com/question-109595.html
Curt recommends the use of 250 ft/lbs of torque when tightening the nuts of their hitch balls with a 1 inch diameter shank like the part # C40034 that you referenced.
The general rule is for a 3/4" shank tighten to 150 ft/lbs For a 1" shank tighten to 250 ft/lbs, and for a 1-1/4 inch shank 450 ft/lbs.
Ops...reread the OP's comments...guess it is the WD hitch head bolts...use the OEM's spec
-Ben Picture of my rig
SDcampowneroperator
South Dakota
Posted: 04/02/19 09:29pm Link  |  Print  |  Notify Moderator
asme spec. 250 lb./ft for 3/4" nc gr. 5 dry bolt in that application. Torque is not an issue as much as shear load because the bolt is not so much a connection as it is subjected to side shear load. Lubes reduce torque spec. depending on type. Machine oil to moly paste, makes a big difference. Moly can reduce torque by 50 %
Posted: 04/02/19 11:36pm Link  |  Print  |  Notify Moderator
Scientifically, as tight as I can get with a 1/2 drive ratchet or my air impact on middle setting. Couple hundred ft lbs.
TBammer
Mid-Michigan
Posted: 04/03/19 06:56am Link  |  Print  |  Notify Moderator
Yeah, or you can do that, which is prolly the best move.
