RV.Net Open Roads Forum: Fifth-Wheels: Slide hydraulic reservoir
 > Slide hydraulic reservoir
usnret
Fulltime RVer
Posted: 04/02/19 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
I need to top of the hydraulic reservoir on my Cardinal fifth wheel. Is ok to use hydraulic fluid from an auto parts store like Auto Zone?
Thanks in advance.
Jim
USNRET
Jim & Judy
2009 Ram 3500 Dually LB
2011 Cardinal 3425RT
The Meandering Maddox's Blog
The Call to Serve
"Heaven must need a hero"
enblethen
Moses Lake, WA
Posted: 04/02/19 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
Look at the unit spec sheet. It should say automatic transmission fluid in most.
Make of the slide unit would help.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
cummins2014
Utah
Posted: 04/02/19 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks in advance.
Jim
Thats what I use , I just bought a quart bottle of Johnsen's Hydraulic Jack Oil from O'reily's . I can see that mine is not ATF, it fairly clear. Been using Johnsen's in mine for several years.
Now if I would pull off one of the hydraulic hose that is leaking in the fitting ,and get the fitting replaced I probably wouldn't have to keep adding periodically [emoticon] My bad !!
Old-Biscuit
Verde Valley
Posted: 04/02/19 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
ATF IS the standard fluid for hydraulic operated slides
Slides should be retracted when adding fluid to reservoir
jtaylor1920
Oregon
Posted: 04/02/19 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
Here is Lipperts recommendation.
Here is a link to the tech sheet.
https://www.lci1.com/assets/content/supp........ng%20and%20Stabilization/CCD_0002088.pdf
Note: Moderator edit to enlarge picture for readability.
* This post was edited 04/03/19 08:18am by an administrator/moderator *
John, Laurie & the 2 Schnauzers (Mazie & Obi)
2016 GMC Duramax Dually
2018 Cardinal 3350RLX
B&W Companion Hitch
ChuckSteed
Mtn Home, Idaho
Posted: 04/03/19 07:43am Link  |  Quote  |  Print  |  Notify Moderator
You need to,look at the color of the fluid..
Not all were filled with transmission fluid..
If the fluid c9,or is honey brown then you need AW32 hydraulic fluid that you can get in an auto store or Wally World
If fluid is red then service with previous posters Lippert PDF.
Lippert says don’t mix fluid types
laknox
Arizona
Posted: 04/03/19 07:53am Link  |  Quote  |  Print  |  Notify Moderator
As long as it's down, why not top off with the stuff LCI recommends to fix the "popping" noises, even if you're not having them? Some sort of additive that's usually found at a Cat dealer. Sure can't hurt anything.
Later: I remembered that it's called "anti-stiction" fluid.
Lyle
* This post was edited 04/03/19 03:45pm by laknox *
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
usnret
Fulltime RVer
Posted: 04/03/19 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all for your advice and comments.
