RV.Net Open Roads Forum: Travel Trailers: Question re axle replacement
 > Question re axle replacement
Huntindog
Phoenix AZ
Posted: 06/05/19 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
gregmisc wrote:
I had uneven tire wear on my original tires and contacted the dealer. The dealer said he doesn’t align axles and sent me to a truck shop. The truck shop said they are not adjustable and could not help me. I finally found a shop that said they could do the alignment but they found both Lippert axles were bent and needed to be replaced. The owner said the Lipperts were not made as well as Dexters so he ordered larger capacity Dexter axles for replacement. I hope this solves my problem.
Having had both brands, IMO, The Lipperts are made better. The difference is that Lippert powder coats them, and Dexter paints them. Other than that they are the same.
They will both build them to a customers spec.
That goes for tube thickness, Hub face spec, ratings, brake sizes etc. Actually just about all of the individual parts are interchangeable.
So you canbuy a weak or strong axle from either company.
I bet your shop was a Dexter dealer.
At any rate, going stronger was a good thing. But it was too bad he felt the need to throw Lippert under the bus. He gets an "A" for the stronger axle recommendation, and an "F" for truthfullness about his competition.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2011 Silverado CC DA big dually.
gregmisc
Teller County, CO
Posted: 06/06/19 09:58am Link  |  Quote  |  Print  |  Notify Moderator
You are probably right about the dealer.
2018 Ford F-150 Lariat 4x4 Supercrew 3.5L V6 ECOBOOST
3.55 Electronic Lock RR Axle
Max Trailer Tow Package 12,700# Tow Capacity
Anderson WDH
2016 Starcraft Launch Ultralight 24 RLS
troubledwaters
Potomac
Posted: 06/06/19 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
So let me see if I got this right. You have had both axles and know better then the truck shop (who works with axles every day of his life) which axle is better. And in your opinion, the truck shop was lying ( "F" for truthfullness).
Did I get that right?
goducks10
There
Posted: 06/06/19 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting. I had a 2010 Heartland Northtrail with 4400lb 3"OD Lippert axles. I needed an alignment and took it to a local big truck/RV alignment shop. The guy doing the alignment said that the axles felt soft so he put in a little extra camber.
Thats my story, take it how ever you want.
BillyBob Jim
US
Posted: 06/06/19 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
ROFLMAO. Lippert, the fine folks who bring you pleather furniture that peels and flakes within two years, shower bases that crack if the user weighs more than 90 lbs, leveling systems that blow seals and hose fittings often along with losing calibration almost every time they're used, electronic control systems that lock up and require constant rebooting, frames that deflect or crack, windows that open themselves while traveling, under powered motors for slideouts which also go out of sync and cause slides to jam, etc etc etc.
You might want to discuss who makes the better axle with some of the hundreds if not thousands of Grand Design owners who had Lippert axles prior to 2018 or whenever it was that Grand Design threw in the Lippert axle towel and switched to Dester.
goducks10
There
Posted: 06/06/19 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
BillyBob Jim
"You might want to discuss who makes the better axle with some of the hundreds if not thousands of Grand Design owners who had Lippert axles prior to 2018 or whenever it was that Grand Design threw in the Lippert axle towel and switched to Dester."
Nuff said. [emoticon]
Huntindog
Phoenix AZ
Posted: 06/06/19 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
I believe you. My current Lippert axles were built to my spec. They are available in different tube sizes and thicknesses. I now have 3" heavy walled tubes. Most manufacturers will not pay up for that. Extra camber by the way will not correct a weak thin walled tube... Well not permamently any way/ The first good sized bump in the road will remove that camber.
mhsmith
Toledo
Posted: 06/07/19 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2001 32'TT. This reason alone makes me think twice about replacing it. it scares the heck out of me as I do not have any poor tire problems and no need to concern myself with an alignment issue. Close guess as to miles on the trailer are around 35k-40k. Tires have been replaced primarily when a tire would blow...at which the whole set got replaced. Current set was replaced in 2016 with D load range and wish I had done that earlier in its life. Up to this point they were C LR tires. The D's just make this thing tow better.
Huntindog
Phoenix AZ
Posted: 06/08/19 02:16am Link  |  Quote  |  Print  |  Notify Moderator
Yep. I have caught so many shops, dealers etc. in lies, and just over all incompetence, that I quit giving them my money many years ago. It helps a lot that I am an advanced DIYselfer. I can do most any thing better than the so called pros.
You gotta realize that in most cases, the person working on your stuff, isn't the best or the brightest... Of course that works both ways. Many of their customers are in that group as well.... And they do not recognize incompetence when it happens to them.
myredracer
Langley B.C.
Posted: 06/08/19 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
I highly recommend you take the trailer to a reputable frame & axle shop with experience in RVs. For a couple hundred $$ or so, you can get a thorough inspection done and possibly even find things you wouldn't have suspected. We did that on a brand new TT when found found a problem the day after we owned it. After going to a frame & axle shop, we eventually got the entire TT replaced under warranty along with a much improved frame & suspension.
I would not trust the dealer and what the dealer might tell you what Lippert told them. We were told Lippert said "it's within spec." which it def. wasn't. Total ****.
Yes, it's not uncommon for spring hangers to be welded in the wrong locations. They can also be bent to one side and if the frame is a weak design, the bottom web of the I-beams can be distorted - we had both these issues plus some others.
I would avoid Lippert's Equa-flex equalizer and go to Dexter or Mor-Ryde. Much better built. Our TT came with Equa-flex and we replaced them immediatly with Dexter plus their wet-bolt kit and sold the Equa-flex on ebay.
I see your TT has a GVWR of 5995 lbs so LRC tires *should* be fine. One possible cause of tire wear on one side of a tire can be loose bearings but if on a fairly new TT and the drums have never been off, it's unlike to be a cause.
Gil, Deb & Dougal a 15 year old Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH, shocks and Endurance LRE tires
2012 GMC Sierra 2500HD crew cab, Bilstein shocks, heavy duty trailering option
