RV.Net Open Roads Forum: General RVing Issues: Valterra pull handle
 > Valterra pull handle
tarnold
georgia
Posted: 04/09/19 08:09am Link  |  Quote  |  Print  |  Notify Moderator
JB WELD worked!
IAMICHABOD
Sunny So Cal 90713
Posted: 04/09/19 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Good to Know that it worked out,now just one more thing to stash in my small tool kit along with my Goop
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
MrWizard
Traveling
Posted: 04/09/19 09:55am Link  |  Quote  |  Print  |  Notify Moderator
The slider valve is closed
The rod comes all the way out ? Of the assembly
Take the rod go to the hardware store
By the next size larger "all thread rod"
Grind/sharpen the tip so it will start into the existing stripped hole is the valve slider
Drill out the entry hole where the rod goes into the assembly
Screw in the new oversize rod you made
And open the dump valve
Now you can install a new valve assembly
OOPS missed the JB WELD worked
good, now onward to the replacement
* This post was last edited 04/09/19 04:49pm by MrWizard *   View edit history
Radiate The Happy
1997 F53 Bounder 36s
CavemanCharlie
Storden,MN
Posted: 04/09/19 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
tarnold wrote:
If we diagram the sentence (y’all remember how to do that) ROD is the subject, the (subject) pulled out. Not the slider. Yes the tank is full. The long screw idea didn’t work. Probably because the screw is the same diameter as the ROD so the threads had nothing to grip. Hoped applying pressure while screwing would allow the screw tip to bite but didn’t. Mixed up some jb weld and put a dab on the end of the ROD. Let set up overnight and will give it one more try this am. I WILL try to reinforce this area when installing a new assembly.
I'm glad the JB weld worked !!! It's amazing what you can fix with that stuff. (Though I have found times it didn't work too)
But, I don't remember how to diagram a sentence. In fact, I don't think that I've ever heard of it. I don't think they taught that in MN when I was a boy. Maybe they do now.
