RV.Net Open Roads Forum: Hitch jack fully extended: Should I be nervous?
 > Hitch jack fully extended: Should I be nervous?
davehultin
Fargo, ND 58104
Posted: 04/07/19 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
The snow is almost gone, and the camper is out of storage and in our driveway, YAY!!!
I always try to get it as level as possible in our driveway so we can open our slide as level as possible, but to get the level camper requires lots of wood, and a hitch jack that's fully extended. Should I be nervous?
Here's what it looks like when it's almost level:
And here's what "almost" level looks like according to the level:
About six more cranks would get it level, if the jack wasn't already fully extended.
Here's a closeup, showing the three stacks of wood:
(FWIW, the bottom two layers are screwed together, and sized to allow the top chuck of wood to either rest in between or go up on top to form one more layer, as pictured.)
You can see in this picture that the front end is almost three feet off the ground!
So with all that wood piled as high as it can, and the jack fully extended, should I be nervous? If we're inside walking around it always feels SO wobbly. I always wonder if I'm asking too much to have the jack fully extended. Do I risk just having the whole thing nosedive on me some day?
Dave Hultin
2010 Ford Expedition, 2018 Gulfstream Cabin Cruiser 28BBS
bluie5
Wisconsin
Posted: 04/07/19 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
I would add more wood so less of the jack is out. When we had our TT I had to use 4 treated 6x6 inch post pieces that I stacked like a pyramid. I also put two pieces stacked under the front stabilizer jacks to add more stability.
2016 Ford F-350 Super Duty CC PSD SRW 4x4
2018 Jayco Eagle HT 29.5BHOK
davehultin
Fargo, ND 58104
Posted: 04/07/19 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
The problem is I can't add any more wood. When I back into the driveway, that stack of wood takes up all the space between the driveway and the (fully retracted) jack.
wanderingaimlessly
SOBOVA
Posted: 04/07/19 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
If you are concerned build your "woodpile" up another level. The width should remain similar to now, the wider, the better, as you gain height.
I had used two 8" concrete blocks next to each other with another 8" block on top and a 2" x 8" on top for my pad for a 28' tt.
If the slope is that bad, just make sure you are well chocked.
Chris Bryant
Arden, North Carolina
If it’s there for a while, lower the hitch on to a jack stand, crank up the jack and add more wood. Reverse to hook back up.
Or put the front stab jacks down- on blocks.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
George3037
Central Square, NY
Posted: 04/07/19 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
Agree to add more wood and add a tongue foot to the bottom of the jack.
bluie5
Wisconsin
Posted: 04/07/19 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
I have a farm jack that I would use to hold the tounge up and raise the jack to put more wood underneath.
MarkTwain
Northern, Ca. , USA
Posted: 04/07/19 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
Leveling your trailer. I would suggest you buy a couple stationary jacks that would fit under your frame on the front of your trailer. Lower your hitch jack so the frame rest on the jacks to take most of the pressure off your hitch jack. I would also lower your rear jacks to help stablize the trailer.
SoundGuy
S Ontario
Posted: 04/07/19 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
A little difficult to tell from your pic but is the trailer even chocked? [emoticon]
I have a significantly sloped driveway so anytime the trailer was parked on it not only was it chocked but I also used a triple stack of 2x under the tongue jack so the jack itself isn't excessively extended when the trailer is level.
2012 Silverado 1500 Crew Cab
2014 Coachmen Freedom Express 192RBS
2003 Fleetwood Yuma * 2008 K-Z Spree 240BH-LX
2007 TrailCruiser C21RBH * 2000 Fleetwood Santa Fe
1998 Jayco 10UD * 1969 Coleman CT380
Yosemite Sam1
Under the pines.
Posted: 04/07/19 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
I would recommend the shoe and more wood considering the jack tubes are both hollow pipes.
My problem though with that much tilt was that the hitch and the coupling would lock up.
