RV.Net Open Roads Forum: Truck Campers: Travel Lite 770P
 > Travel Lite 770P
ykphil
Yellowknife
Posted: 04/08/19 10:11am Link  |  Quote  |  Print  |  Notify Moderator
I have a Travel Lite 770P which is a fiberglass popup truck camper with electric pop up top. Is there a way to open/close the top manually in case of one or more of the four electric motor failure? The manual is very generic and has no useful information, and my attempts to reach the manufacturer were unsuccessful. Any tip or recommendation would be welcome. Thanks in advance.
work2much
Jackson Ca
Posted: 04/08/19 10:24am Link  |  Quote  |  Print  |  Notify Moderator
It looks like you can. Check out this article from TC magazine. It sounds like there is a tool to crank manually.
https://www.truckcampermagazine.com/slid........new-camper-2013-travel-lite-770p-pop-up/
2017 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2018 Host Mammoth. 1080 Watts solar. 600 AH usable LFP battery. Magnum 2800 Watt inverter.
2018 Jeep Wrangler Unlimited toad.
ykphil
Yellowknife
Posted: 04/08/19 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
***Link Removed***
Great, thank you for the quick reply. I had read this article some time ago before getting my camper, but that part had not really registered. I bought it used and the tool was not included, so I will continue pestering Travel Lite to get it. Cheers.
ykphil
Yellowknife
Posted: 04/17/19 11:38am Link  |  Quote  |  Print  |  Notify Moderator
I finally got a hold of Travel Lite, it took quite some time to get a response. Unfortunately, they were of no help since they discontinued their popup line a few years ago and do not provide any part, support, or assistance for their former popup line. They passed the puck to another company, Camper and Recreation Inc. which was also of no help as they only deal with manual lift systems.
So I am back to square one and still looking for a solution. Any lead will be greatly appreciated.
joerg68
St. Ingbert, Germany
Posted: 04/17/19 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
I do not know the type of roof lift in your camper. Is it anyhthing like the Rieco Titan system described here? With independent actuators?
https://www.truckcampermagazine.com/news........-titan-on-palomino-rv-s-new-lift-system/
page 7 of this PDF deals with their manual crank override:
http://www.riecotitan.com/flyers/erls_2015.pdf
Or does it use a single lift motor and cables? Can you describe the operating principle?
A few pictures of your system might help to extract some more information from the crowd. It was probably not limited to Travelite.
mkirsch
Rochester, NY
Posted: 04/18/19 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Odds are pretty good that they didn't reinvent the wheel. For example, my popup uses a "Heco" lift system even though it was built by Palomino.
ykphil
Yellowknife
Posted: 04/18/19 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the links. The lift system on my camper uses four independent actuators that look exactly like those described in the Rieco-Titan brochure, with the exception of the wall control switch. I called Rieco-Titan who were not able to tell me whether they built the lifts for Travel Lite but I suspect they did at one point. In the truck camper magazine, Travel Lite VP says they partnered with an industry leader, so chances are my lift was manufactured by Rieco-Titan. The flex drive costs less than $10 so I just ordered it. Hopefully, it will work.
ykphil
Yellowknife
Posted: 04/22/19 10:23am Link  |  Quote  |  Print  |  Notify Moderator
...only to find out, after removing two side panels behind some cabinetry to access the hidden actuators, that one of them had a tiny little faded sticker that said "Smith Richards" who, after contacting them, are indeed the manufacturer of my camper's lift system...
 > Travel Lite 770P
