RV.Net Open Roads Forum: Tech Issues: Powerpole Info Needed
 > Powerpole Info Needed
rk911
Wheaton IL
Posted: 04/09/19 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
theczar wrote:
Thanks all for your comments.
It is intended for a 400 watt portable Solar system So I believe 30 amp should be sufficient.
My soldering skills are not very good so want to stick with crimping. I am looking for specific Crimpers. I have seen some from under $20 to over several hundred dollars. Looking for experienced opinions for a low cost but sufficient quality for a weekend warrior like myself.
i bought my powerpoles and tool from West Mountain Radio
'73,
rich, n9dko
Remember...if you don’t know where you’re going you're bound to end up somewhere else.
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
Wherever I happen to park
Posted: 04/09/19 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
IF I can find it I use a professional grad ratchiting crinper I got to admit the crimps it turns out look 100% professional. I have used it on wire up to 10ga in fact teh wire is right in front of me. 40 amp poles or so they are rated.
Last pair I put on I used the "Crimp" feature of a pair of needle nose pliars but it was much smaller wire and I had do do some additional "Crimping" to get it to grip properly but its solid now. THat connection is in the other room.
Go to West Mountain Radio and look over all the Power Pole stuff they carry...
Home is where I park it.
landyacht318
Near a large body of salty water
Posted: 04/09/19 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
The 30 amp powerlines are simple to crimp 12 to 14awg wire. For 10 awg you need the 45 amp. Or destrand it to 12awg thickness.
The 45 amp powerlines are difficult to crimp properly without their special tool.
I went years crimping 8awg Into the 45s before acquiring the special anderson crimptool.
I bought some dies for flag terminals and insulated terminals. Which fit into the anderson crimpers making them multipurpose. I also remove the little plastic anderson spoon contact holder and crimp non insulated terminals with the anderson dies.
The 30 amp contacts are very easy to assemble without the special crimper if one has a dimple crimper But the special C likely does a much better physical and electrical connection.
If you are near NCSD coastal. I can make up your cables if you bring the 45 amp powerpoles.
2manytoyz
Central FL
Posted: 04/10/19 08:34am Link  |  Quote  |  Print  |  Notify Moderator
I've been using Anderson PowerPole connectors since the 90s. I use them at home, and at work. I've purchased and installed thousands of them. Absolutely excellent product!
Be warned there are cheap knock-offs that don't fit/work as well. Found those on eBay and Amazon (surprised me). Sent those back.
Consequently, I buy all my stuff through Powerwerx (no affiliation).
https://powerwerx.com/anderson-power-powerpole-sb-connectors
I have a couple of their crimpers, which work much better/faster than soldering the contacts to the wires.
The nice part is you can buy a kit of the 30A size (most common), and order additional 15A and 45A contacts. All three sizes fit in the same housing, but these give you the ability to use different sized wires for different applications. I also have a mix of colors for differentiating different circuits.
Robert
Merritt Island, FL
2015 Forest River Georgetown 328TS
2006 Jeep Wrangler Unlimited TOAD
Falcon 2 Towbar, Roadmaster 9400 Even Brake System
http://www.2manytoyz.com/
Posted: 04/10/19 10:29am Link  |  Quote  |  Print  |  Notify Moderator
One note on power poles.. They do tanish and if you are not hauling enough current to burn it off you need to unplug-replug from time to time.
2manytoyz
Central FL
Posted: 04/11/19 08:39am Link  |  Quote  |  Print  |  Notify Moderator
I'm installing an outlet cover plate in the motorhome that has a couple of Anderson Powerpole connectors mounted to it. This will be mounted into a low voltage style electrical single gang box (not enclosed).
This will allow me to plug in Ham radio gear (etc.) that I'm already using Anderson connectors.
I designed the plate in Fusion 360, and printed it on a Creality CR10S printer.
The file is here: https://www.thingiverse.com/thing:3554718
theczar
Southern CA
Posted: 04/13/19 08:09am Link  |  Quote  |  Print  |  Notify Moderator
A lot of great info. Thanks to all.
Posted: 04/13/19 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
Not of any help but I was digging around last night looking for something (no joy but turns out I did not need it) and Murphy's law of how to find stuff kicked in.. Since I was NOT looking for the power pole crimper.. I found it. A nice west mountain ratching job.. along with my older stock of PP's Too bad I didn't need it but on reflection I could have used it.
The Problem I was trying to fix was an intermittent between a 12 volt accessory outlet and the 5 Volt USB device that plugs in. turns out the problem was in the socket itself so I cut the thing off. Fired up my new soldering iron (It gets nice and hot if I open the gas valve all the way) and soldered the leads direct to the adapter Taped it up good and now its ... Working. Very well.
Benz-o-Matic soldering iron. Run on Ciggy Lighter Butane. Very nice Very hot.
Tom_M
New Hope, MN
Posted: 04/15/19 06:35am Link  |  Quote  |  Print  |  Notify Moderator
You can find everything you need at Powerwerx.com. Their prices are reasonable. I used SB-50 connectors for my portable solar install. The SB series connectors come in several colors but make sure you stick with one color because they are keyed differently. For instance a grey connector will not plug into a red one.
Tom
2005 Born Free 24RB
Towing 2013 Smart Car
Tom_M
New Hope, MN
Posted: 04/15/19 07:13am Link  |  Quote  |  Print  |  Notify Moderator
For us folks without a 3D printer here's a solution available on eBay: Keystone Powerpole adapter
It appears that this is a 3D printed item. The wall plate is not included.
