RV.Net Open Roads Forum: Class C Motorhomes: Smaller Drivers seat
 > Smaller Drivers seat
TMJ1624
Helena
Posted: 04/09/19 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2004 Holiday Rambler on a 450 Ford chassis, problem is me, I’m a big guy and can’t move it far enough back to comfortably relax to drive it. Question: can a different seat be put in......
bobndot
Posted: 04/09/19 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
Sometimes you can re-drill the seat on its base.
Sometimes the base can be moved as long as you have room behind the seat.
If you're near an auto body shop, inquire to see what they can fabricate. It might not cost too much to do and they would be able to see where they can drill if need be.
ItsyRV
Desert SW
Posted: 04/09/19 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
Without knowing the exact model, you are either hitting the step-up preventing it from moving any further back or the furniture is preventing the back from reclining. Which is it as the fix is different.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
TMJ1624
Helena
Posted: 04/09/19 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it hits the wall between slide out and drivers seat......
romore
Okanagan valley British Columbia
Posted: 04/09/19 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
That is my biggest beef with that style of vehicle.
IAMICHABOD
Sunny So Cal 90713
Posted: 04/09/19 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
A very easy way to get around this type of problem is to buy one on a Chevy Chassis [emoticon]
* This post was edited 04/09/19 09:26pm by IAMICHABOD *
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
Tyler0215
Iowa
Posted: 04/10/19 07:50am Link  |  Quote  |  Print  |  Notify Moderator
If it's up against the wall, there isn't much you can do.
ron.dittmer
North-East Illinois
Posted: 04/10/19 08:42am Link  |  Quote  |  Print  |  Notify Moderator
The slide out interfering with the travel of the front seats is a common complaint with many motor home manufactures.
When internet shopping, an easy visual indicator is to note the transition wall coming straight out sideways, then the slide out being right up close to that wall. Here is one example.
To avoid the condition, seek a motor home with an angled transition wall that is more aerodynamic. It places the slide out significantly farther behind the driver seat as seen here.
TMJ1642,
If your issue is serious enough, seek out a driver seat with a thin backrest. They may be marketed as "Sport Seats". Most RV seats have exceptionally plush back rests which reduce travel to an already tight condition. A thin backrest may increase seat travel by as much as 4" depending on how plush your current back rest is.
* This post was edited 04/10/19 12:23pm by ron.dittmer *
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
winnietrey
seattle
Does it, hit the wall of the slide or the trim piece of the slide ? On ours it hit the trim piece. Took a sawsall to the trim piece, cut out a notch, so to speak. So the seat back could tilt further back. Solved the problem
* This post was edited 04/10/19 08:54am by winnietrey *
dicknellen
Fallon Nevada
Posted: 04/10/19 10:47am Link  |  Quote  |  Print  |  Notify Moderator
When I looked at buying a RV with a slide either Class C or A, I would always have the slide put in before sitting in the drivers seat. If I wasn't able to get comfortable in the drivers seat I didn't look any fruther.
