RV.Net Open Roads Forum: Fifth-Wheels: Should We Get A New Hitch?!
 > Should We Get A New Hitch?!
MFL
Midwest
Posted: 04/09/19 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, what hitch, and how far from the hitches pin center to back of cab? I have towed 2 different FWs with Ford 6'9" beds without issue. The first FW did not have a rounded front like my current one. The one now, with EZ turn does not even come close in fairly tight turns. My B&W hitch pin center is about 40.5 inches from back of cab.
A few inches forward makes a big difference, but I think I could go to 38 inches from cab, to pin center of hitch, and still have no issue. My Ford rear axle center to cab is 41 inches.
Jerry
cpaulsen
Oregon
Posted: 04/10/19 03:49am Link  |  Quote  |  Print  |  Notify Moderator
I did not gamble with my newer truck and 5th wheel......went to a Pullrite Superglide and do not worry about hitting the with my shortbed.
cpaulsen
BugsRLB
NH
Posted: 04/10/19 09:10am Link  |  Quote  |  Print  |  Notify Moderator
We have a Reese hitch that fits in the 4-hole puck system (or whatever it's called) of our Ford F350.
2018 Ford F350 SRW 6.7PowerStroke/6 Speed Auto
2017 Jayco Eagle 321RSTS
laknox
Arizona
Posted: 04/10/19 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Like the others, need to know what hitch you have. If you =do= happen to have a B&W, I can tell you that they will not warrant their hitches if you use a "swiveling" pin box, since it, in effect, moves the king pin back.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 61 Year Member
Bob Sue
Farmington,Mi
Posted: 04/10/19 09:43am Link  |  Quote  |  Print  |  Notify Moderator
I have the pull rite auto slide, great hitch, never worry about it. The hitch actually comes out easy with the help of one person, or I can disassemble it, and pull it out myself in 15min or less.
Bob&Sue
2013 Open Range Roamer 5th
2011 Ford F-250
6.7 litre PSD
Pullrite Superglide
C.B.
APPLETON WI USA
Posted: 04/10/19 10:30am Link  |  Quote  |  Print  |  Notify Moderator
Going into 16th year with the Pullrite SuperGlide.
Well worth the money every time I make a turn.
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
CB Family Fleet
Butch/Barb=2013-Cedar Creek 36CKTS
Duane/Holli=2005-Cedar Creek 362BBS
Kris/Katy=2006-Cherokee 32B
MFL
Midwest
Posted: 04/10/19 10:36am Link  |  Quote  |  Print  |  Notify Moderator
Is it adjustable ahead/back? Measure from center of hitch hole, jaws closed, level ahead to back of cab, to check distance. If need be, the hitch pin center, can be right over rear axle center. You cannot expect to back to a 90 degree angle, but most turns forward, should not cause the issue you encountered.
Jerry
Njmurvin
Simi Valley
Posted: 04/10/19 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Superglide owner here. Yeah, it's heavy. I have an electric cable winch I bought at HF mounted in the rafters of my garage. It snaps that hitch out of there in no time at the push of a button. I lower it onto a cart which I store under the fifth wheel overhang.
2004.5 Dodge 3500 4x4 Laramie SWB QuadCab CTD, 48RE (auto), Putco Boss Bars, Pullrite Superglide, LineX, Prodigy, PacBrake
2011 Arctic Fox 27-5L
BugsRLB
NH
Posted: 04/10/19 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry
No it is not adjustable. It fits in 4 factory holes in the bed. Was thinking on some type of movable rotating kingpin.
Terryallan
Foothills NC
Posted: 04/10/19 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
Is it a short bed or long bed truck?
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
