RV.Net Open Roads Forum: Tow Vehicles: Exhaust Brake Buying...
Search only in Tow Vehicles
 > Exhaust Brake Buying...
Gulfcoast
Alabama
Posted: 04/09/19 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
2006 - Dodge - 2500 - 5.9 - Auto
Ready to install an exhaust brake on my 5.9.
Which brand do you prefer and why?
Thanks
path1
Varies with weather
Posted: 04/09/19 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
* This post was edited 10/24/19 10:25am by path1 *
ScottG
Bothell Wa.
Posted: 04/09/19 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
The OP's 2006 Cummins is FULLY exhaust brake ready. Valve springs and trans are built for it with no modifications.
I've had a Pac "brake" for more than 10 years without any issues.
* This post was edited 04/09/19 05:03pm by ScottG *
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Bionic Man
Colorado
Posted: 04/09/19 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
I put a Jacobs on my 03 when it was brand new. It worked well. I did have to replace something (I can't remember what now) when I owned it. Seemed like an expensive fix - something like $800.
Anyway, if you go that route, I suggest you find a Cummins dealer and have them do the work, as it was about half price what the Dodge dealer wanted.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
NRALIFR
Truck Camping Out West
Posted: 04/09/19 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
I had a US Gear D-Celerator on a ‘95 F350 and loved it. Never had a problem with it.
In some respects I liked it better than the type of exhaust brake/tow-haul mode on my F450.
[emoticon][emoticon]
* This post was edited 04/09/19 05:09pm by NRALIFR *
2001 Lance 1121 on a 2016 F450
Durb
NW
Posted: 04/09/19 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
I like the Pacbrake PRXB because it is the one I have. Haven't driven another brand.
Some niggles: The air holding tank bleeds down when parked so the compressor is working at the same time as the grid heater. Not a problem in my mild climate, could be hard on the batteries if really cold. With the Pacbrake on, the torque converter stays locked to lower RPMs and sometimes causes the engine to lug. Downshifts are more abrupt; I mitigate this by using tow haul and throttle position, never happens now. Sometimes, but very seldom, the brake won't actuate. I turn off then on and slight accelerator and it starts working. Pleasant sound lets you know it is working. Deactivates at 24 MPH.
I owned the truck without the Pacbrake. I wouldn't tow in the mountains without it. It activates when cold and at idle to help warm the engine.
rhagfo
Portland, OR
Posted: 04/09/19 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
I had a PacBrake on my 2001 5 speed manual, getting ready to install one on DD 2004 3500 DRW with auto.
RAS43
Littleton,CO
Posted: 04/09/19 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
Had one on my `99 7.3l and it held back okay. My issue with it was it would not open at times at the bottom of the grade. Had to pull over and wait. A second, larger size brake did the same thing. I eventually traded the truck in so someone else had to deal with it.
Old-Biscuit
Verde Valley
Posted: 04/09/19 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
I installed the US Gear D-Celerator on my 2007 5.9L CTD in 2008.
4" main butterfly with a 2" bypass butterfly that controls back pressure (controls for 59# max back pressure)
It is a simple straight forward control......12V DC HD solenoid with a main circuit board controller.
It 'test cycles' (close/open) when truck key is turned on.
Test Cycle checks function, exercises butterfly valve and limits soot build up
Pressing on accelerator pedal cancels test cycle which may cause problems with sticking butterfly
11 years and it functions great. Use it ALL the time.
Towing and running empty.
Holds 55 mph truck/5th wheel 6% grade (22000K GCVW)
Posted: 04/09/19 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
Put a BD brake on about 6 years and 60k ago. No issues, works great.
Compressor works well for airbags and bike tires. Plumbed a valve and air hose into the air line to the brake.
