RV.Net Open Roads Forum: Travel Trailers: new batteries for trailer
 > new batteries for trailer
Sam Spade
North Central Florida
Posted: 04/12/19 06:45am Link  |  Quote  |  Print  |  Notify Moderator
DesertTracker wrote:
but is this the correct convertor for 6V batteries? Thanks for any help.
Yes, likely fine.
Two 6's in series makes......one LARGE 12.....so any charger with a large capacity should be OK.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
SoundGuy
S Ontario
Posted: 04/12/19 07:31am Link  |  Quote  |  Print  |  Notify Moderator
... and was expecting to upgrade to two Costco 6V batteries, but is this the correct convertor for 6V batteries?
Of course, as you won't be charging those 6 volt jugs individually but rather connected in series so they're the equivalent of a single 12 volt jug.
2012 Silverado 1500 Crew Cab
2014 Coachmen Freedom Express 192RBS
2003 Fleetwood Yuma * 2008 K-Z Spree 240BH-LX
2007 TrailCruiser C21RBH * 2000 Fleetwood Santa Fe
1998 Jayco 10UD * 1969 Coleman CT380
philh
Belleville MI
Posted: 04/12/19 09:48am Link  |  Quote  |  Print  |  Notify Moderator
At the risk of hi-jacking the OPs thread, I have a related question: I just bought a Progressive dynamics Wildcat 4655L that has a 4 stage charger (14.4, 13.6, 13.2, 14.4 desulfation), and was expecting to upgrade to two Costco 6V batteries, but is this the correct convertor for 6V batteries? Thanks for any help.
Contact the dealer that sold you that unit.
DesertTracker
Ridgecrest, CA
Posted: 04/12/19 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
I called Progressive Dynamics who verified that there is a PD9260C-14.8 deck mount converter that does produce the 14.8 volts needed by the Trojans. The only retailer is Best Converter which is where I purchased the 4655L Wildkat which is set for 14.4 volts. The deck mounts are slightly more work to put in, so I'm trying to decide if it is really worth the trouble to return the 4655 and re-order the 9260-c and put in the deck mount for the extra 0.4 volts. Opinions welcome.
2011 Keystone Springdale 189
2000 Dodge 2500 4x4 V10 4.10
philh
Belleville MI
Posted: 04/12/19 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
It looks like the 4655L WC is a straight installation. How does the 9260-c get installed? Be nice if they had a 4655L+
DesertTracker
Ridgecrest, CA
Posted: 04/12/19 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
The deck mount, in my case would screw to the floor behind the power center (fuse panel) and does not directly wire into the power center, it needs a receptacle to plug into but does feed the 12 volt circuits thru the power center. The Wildkat was going to be an easy installation: it just replaces the inadequate WFCO unit in the bottom of the power center, and the 9260C-14.8 is not much harder, but different. I have the room behind the fuse box, and room for another 120V breaker and circuit, it is just working in the confined area behind the fuse box that adds a little more difficulty. Again, just not sure its worth the trouble...
philh
Belleville MI
Posted: 04/12/19 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
has to plug in? Can't hard wire it?
Mine is underneath the fridge... so not only is there going to be a shortage of space, I'm going to be on the floor too.
I'm buying the GC2 batteries next month, so I'm going to have to do something soon.
azrving
Oatman
Posted: 04/12/19 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
Well.... 14.4 is sure better than 13.6
Sam Spade
Posted: 04/13/19 07:00am Link  |  Quote  |  Print  |  Notify Moderator
What improvement do you hope to achieve with 14.8 ?
I doubt that whatever small gain you might make won't be worth the time and trouble.
Maybe you should call the company back and ask THEM.
Others here will, no doubt, supply more information.
Just beware of the "purists" who MUST have the best available, no matter what the trade off.
pianotuna
Regina, SK, Canada
Posted: 04/13/19 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Please do yourself a favor and get the 14.8 volt version.
Regards, Don
