RV.Net Open Roads Forum: Fifth-Wheels: Tailgate question
 > Tailgate question
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 04/12/19 08:51am Link  |  Quote  |  Print  |  Notify Moderator
It cost me about 175 bucks to repeat the OEM back up camera in my V-Box. Little black dot below the V-Box belt line in the center. You can see the cable coming up to the V-Box. RAM tailgate lock/camera cable unplugs below tail gate and came with blank connectors to protect the pins when it is removed. Chris
* This post was edited 04/12/19 09:04am by Me Again *
Wanderer26
Niles michigan
Posted: 04/12/19 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
Thankyou all for the tips. I will be keeping my OEM tailgate as i use the backup camera all the time when unhooked.
2manytoyz
Central FL
Posted: 04/12/19 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have a 5th wheel, but I do have a 2010 F150 that I'd remove the tailgate to take our golf cart when towing our previous travel trailer.
Each time I'd have to climb under the vehicle to disconnect the tailgate camera. I finally decided I didn't like being without the camera when unhitched, and the tailgate is at home.
I found the wiring diagram online for mine. Your newer truck might be the same, if not, someone has a diagram online:
I connected a cheap license plate camera to the modified stock camera connector to add a 12V plug and an RCA plug to connect. This made hitching MUCH easier, and still gave me a backup view when not towing.
I then went a step further, put a camera on the back of the travel trailer, and would connect that cable to the modified F150 camera connector. The image below is the monitor built into the rear view mirror, looking behind the travel trailer.
I mounted the trailer camera in the rear tire cover:
Rather than mount the camera to the license plate, putting it near your 3rd brake light would probably help hitching your 5ver.
Robert
Merritt Island, FL
2015 Forest River Georgetown 328TS
2006 Jeep Wrangler Unlimited TOAD
Falcon 2 Towbar, Roadmaster 9400 Even Brake System
http://www.2manytoyz.com/
Range Maggot Bob
Missouri
Posted: 04/12/19 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
Puddles wrote:
Super_Dave wrote:
Lockable tailgates are certainly available. You might have to go to a license plate style backup camera versus the stock Ford camera system.
X2... have not had anything blow out of the bed since I switched to a v slotted T gate.
That's funny you should say that. I have a v-tailgate, and last night I loaded up a plastic cart I had built to haul supplies from the house out to our trailer. Went to unload it this morning before work, and it was gone. Blew out somewhere along the highway. And we have lost stuff with this type of tailgate, but never have to lower it to hook up. Don't get that part.
RollandB
Albany, Or
Posted: 04/13/19 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Crutchfield has several cameras that might be able to be added to the fifth wheel tailgate maybe below the handle to open it and between the louvers. Here is one.
https://www.crutchfield.com/p_070ARC600/Axxera-ARC600.html
2005 Silverado 3500 Crew Cab Long Box, Duramax/Allison, B&W Companion, TST507's
2016 Artic Fox 27-5L
Veebyes
Posted: 04/13/19 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
bpounds wrote:
I actually need the V-gate, for reasons I won't repeat again.
My truck is an antique so no tailgate camera for me. But it would be extremely easy to add a camera to a quality V-gate. You could even use the Ford logo style if you wanted.
I also have a V tailgate. Looks to be the same manufacturer as this one but one, maybe two louvres shallower. I still need to be careful with it & have a couple dings in it when not enough care was given.
After awhile you learn how high you need to be if you have lowered the trailer front end after hitching. Every trailer is different. My leg switches are under the overhang driver side. I raise the trailer till my nose touches dead center of a front corner marker light above the switches. Perfect clearance on flatish ground to go over the V & touch the 5th wheel at center of plate.
2007 Alpenlite 34RLR
bpounds
Sophmore Brain...
Posted: 04/13/19 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
My pin clears the vee easily if I am on reasonbly level ground. But every rig will be different. Varies by how high your hitch head is, and how low your pinbox is. Two rigs with the same bed clearance, one could hit and the other clear. You still have to be careful. I bumped mine last season. Ground wasn't level.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
 > Tailgate question
