RV.Net Open Roads Forum: Fifth-Wheels: Pullrite or Demco Superslide for a short bed.
 > Pullrite or Demco Superslide for a short bed.
Crabbypatty
Long Island, New York
Posted: 04/11/19 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
Upgrading to a fiver from a TT. We have a short bed so Im looking for an automatic slider. Seems like Ive narrowed it down to two. Pullrite Super Glide or Demco Superslide. We are getting a fiver with a gross weight of 12,000 pulling with an f250 short bed. Thoughts concerns? Tips tricks and mods. Your experienced replies will be greatly appreciated.
Happy Trails
John, Lisa & Tara">">">
2015 F250 4x4 Platinum, 6.2L 6 spd 3.73 gears, Reese 12klb w/dual cam, Prodigy, Sunny Brook Sunset Creek 298 BH, Trojan 125's, 448 watts Solar Morning Star 45, Honda EU3000, Dish TV, Xantrax Pure Sine 2000, Wilson Cellular Ant/Amp
JIMNLIN
Oklahoma
Posted: 04/11/19 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
Just sayin' but If your new 5er has the rounded notched front corners you won't need a slider.
schlep1967
Harrisburg, PA
Posted: 04/11/19 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
I've been using a pull rite for 9 years. No problems in that time.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
Walaby
Georgia
Posted: 04/11/19 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
I chose Pullrite over Demco. Very happy with my choice thus far.
You never need a slider, until you do. I figure this is hopefully the only hitch I'll have to ever buy, or at least for a long time. Having the auto-slider is a peace of mind.
One thing the Demco has as an advantage over the Pullrite, in my opinion, is the capture plate. Demco's capture plate is part of the hitch. Pullrite's capture plate you purchase separately, and depending on your pin, you have to purchase a different one.
Demco slide operates with a gear. Pullrite slides and rotates between two way tubes. Don't know about maintenance with Demco, but Pullrite only requires WD-40 spray on the way tubes, and the turntable shaft.
At the end of the day, I think they are both good choices. I just decided to go with the Pullrite and happy with the choice.
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
RickLIght
Washington
Posted: 04/11/19 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
I did a lot of research first and then got a quote for a Pullrite slider from my dealer. It just seemed a better option overall.
Then found it on CARid.com significantly less expensive. So much less I was concerned there was some kind of mistake. Several hundred miles later I have no complaints at all.
Rick,
2019 Grand Design Reflection 150 273MK
2015 Ford F350 Lariat Powerstroke
PullRite Superglide
cpaulsen
Oregon
Posted: 04/12/19 05:23am Link  |  Quote  |  Print  |  Notify Moderator
Went with a Pullrite for my F250 sb and has worked just great. Have the notched corners on my new 5th wheel but sure like the confidence in the Pullrite. Little WD-40 on the way tubes and thata all you need!
cpaulsen
southernsky
Ponchatoula La.
Pullrite for 10 yrs and many many mile with no complaints. Do know anything about Demco
2011 Ram 3500 DRW Mega Cab 6.7 CTD 4X4
2016 Grand Design Solitude 369RL
PullRite SuperGlide 5th Airborne
Crabbypatty
Posted: 04/12/19 05:41am Link  |  Quote  |  Print  |  Notify Moderator
I believe that Demco is a new hitch. Seems like the majority of people like Pullrite, but that could also be as they have been around for awhile.
C.B.
APPLETON WI USA
Posted: 04/12/19 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Going into 16th year with 16K Pullrite Superglide.
Great hitch, no regrets.
I do have Demco's Glide Ride pin box. Very happy with it.
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
CB Family Fleet
Butch/Barb=2013-Cedar Creek 36CKTS
Duane/Holli=2005-Cedar Creek 362BBS
Kris/Katy=2006-Cherokee 32B
djousma
SW Michigan
Posted: 04/12/19 08:25am Link  |  Quote  |  Print  |  Notify Moderator
I have the Demco hijacker autoslide. Works very well, but very heavy. A plus for the demco is that if you have a standard pinbox (not moryde), then you dont need a capture plate. They have a rail support system on the hitch head.
That said, my next truck will be a long bed for the larger fuel tank, and I'll be going to a B&W just for the simplicity, and reduced weight.
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
2017 Forest River Cardinal 3850RL
