RV.Net Open Roads Forum: Fifth-Wheels: Pullrite or Demco Superslide for a short bed.
 > Pullrite or Demco Superslide for a short bed.
Bird Freak
Dallas Ga.
Posted: 04/12/19 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
Been using Pullrite for 10 yrs. No problems at all.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
Hammerboy
Zeeland, MI
Posted: 04/13/19 06:04am Link  |  Quote  |  Print  |  Notify Moderator
My previous fifth wheel and truck I had the Pullrite Super glide and it is a very good hitch. The only frustrating part of it though is I think you need to be within 7 degrees or so when you hitch and unhitch. If more than maximum angle you need to unhitch leaving the head attached which isn't so bad but a pain when hooking back up. If you need a emergency tow of your fifth that may become a problem as well because of the adapter plate.
Now I have a B&W manual slider because I need to slide it in the maneuvering position so I can have a little more clearance when I back it down the hill to our barn.
Dan
2013 Chevy crew 2500 HD Duramax
2017 Wildcat 29rlx fifth wheel
Walaby
Georgia
Posted: 04/13/19 07:09am Link  |  Quote  |  Print  |  Notify Moderator
The tow issue is easily resolved. The capture plate is easily removed.
Having said that, if for whatever reason, you have to use your truck/hitch to tow someone else's 5er, that could be a problem for sure.
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
Hammerboy
Zeeland, MI
Posted: 04/13/19 07:50am Link  |  Quote  |  Print  |  Notify Moderator
Mike
That is true, I had mine tack welded as I issues with some of the screws that held it on shearing off.
Dan
C.B.
APPLETON WI USA
Posted: 04/13/19 11:03am Link  |  Quote  |  Print  |  Notify Moderator
Mike
Here's how I resolved the issue using the my Superglide
to tow someone else's 5th wheel
Made a Slide Stop Adapter so I can tow other 5ers that don't have wedge plate.
Front end is notched to fit against Turn table cam arm assembly.
Adapter fits in between slide rails. then is tightened and jam nutted in position to stop slide from working.
Now I can tow any fifth wheel.
Someone else towing my 5th wheel.
Modified wedge plate for quick install and removal.
Drilled holes inside of the wedge of the wedge plate.
drilled matching holes in pin box and welded nuts inside of pin box.
Made a pin set up on front of pin box and wedge plate.
If my 5er needs to be towed by someone else,pull pin, take out 2- bolts, good to go.
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
Butch/Barb=2013-Cedar Creek 36CKTS
Kris/Katy=2006-Cherokee 32B
thetechie01
Olympia, WA
Posted: 04/13/19 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
I was looking at the same things. We just sold our TT and looking at a 5'er tomorrow. In the end, I decided to get the Andersen Ultimate hitch. I have the factory installed gooseneck in my 2012 f-350, and it just bolts on in about 2 minutes. It is super light and easy for one person to get in and out of the truck. I also really like that I didn't have to know the trailer/pin box that I needed to get the capture plate for, it is universal
My dad had a pull-rite years ago, and it worked great. I originally was going to go that route, but the weight difference is what really sold me. The andersen also makes a solid connection because of no other moving parts for sliding
2007 Coachmen 31DSB pulled by a 2012 F350
Campinfan
Washtenaw County, Michigan
Posted: 04/15/19 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Demmco Autoslide. I really like the bar that goes across the jaws. It keeps the trailer locked to the hitch.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
Crabbypatty
Long Island, New York
Posted: 04/16/19 04:21am Link  |  Quote  |  Print  |  Notify Moderator
It seems that most of the votes here and other places are for the pullrite. What put me over the top was calling pullrite and speaking with a technician there. He took all the time i needed in answering my questions. So I bought the Pullrite Superglide 2700 16K with the clean bed technology mounting system. Thanks for all the input.
John, Lisa & Tara">">">
2015 F250 4x4 Platinum, 6.2L 6 spd 3.73 gears, Reese 12klb w/dual cam, Prodigy, Sunny Brook Sunset Creek 298 BH, Trojan 125's, 448 watts Solar Morning Star 45, Honda EU3000, Dish TV, Xantrax Pure Sine 2000, Wilson Cellular Ant/Amp
Crabbypatty
Posted: 05/02/19 04:30am Link  |  Quote  |  Print  |  Notify Moderator
First Tow with a FW and the pullrite super glide 2700. Worked flawlessly. Even unhtiching on an acute angle. Just pulled the to pins and lifted the FW. The hitch head popped off. Worth the time and and $ installing. Very little bucking.
N-Trouble
NorCal
Posted: 05/02/19 08:27am Link  |  Quote  |  Print  |  Notify Moderator
Was in the same boat 4 years ago and decided to skip the heavy slider and go with the Andersen. Absolutely no regrets and have never been in a situation where slider is needed.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
