RV.Net Open Roads Forum: Class C Motorhomes: Strong sweetish odor
 > Strong sweetish odor
Knowharm
Us
Posted: 04/12/19 02:29am Link  |  Quote  |  Print  |  Notify Moderator
Hi. Please help. I have searched the internet and could not find my exact question posted. First time in an rv. Rv toilet had the very faint typical rv sewage smell when we started trip 2 days ago. Today my wife “had to hold the flush valve open and let it run for a really long time” [emoticon]
But now there is a disgusting, sort of sweet smell, not quite like anti freeze, coming from the toilet and is permeating if I turn vent off.
Does anyone know what this odor may be and what I can do to kill it?
Thanks for any help!
gbopp
The Keystone State
Posted: 04/12/19 03:54am Link  |  Quote  |  Print  |  Notify Moderator
Welcome to the forum.
Did you dump and flush the black tank? It sounds like it may have RV antifreeze in the tank.
I would rinse the black and grey tank.
Also, give us the make/model of your RV. Maybe someone had a similar problem.
If there is RV antifreeze in the tanks, another possible problem could be a stuck air admittance valve.
* This post was edited 04/12/19 04:03am by gbopp *
bobndot
Posted: 04/12/19 04:11am Link  |  Quote  |  Print  |  Notify Moderator
once you resolve this. use the tanks properly and flush them both using water to keep them clean.
check your plumbing, make sure your vent to the roof is not blocked, open the end cap and take a peek down the tube to see if it appears clear, not blocked by something.
try the Geo Method to clean the tanks. read below rvnet post for link to instructions. Once its clean, many people simply use water to keep things clean.
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27808130/print/true.cfm
azrving
Oatman
Posted: 04/12/19 05:19am Link  |  Quote  |  Print  |  Notify Moderator
The toilet should have a little bit of water laying in it. There is a rubber seal on the ball/slide valve that must seal good enough to hold water.
I had an older tt with a bad seal at the base of the toilet that had a constant slight odor.
Knowharm
Us
Posted: 04/12/19 06:25am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies, other than the cheese guy. It is a Thor siesta 24st. It is a rental. We picked it up yesterday for a 9 day trip.... toilet holds water. Owner said all tanks were flushed, but I’m finding that it appears that their must have been a quick turnaround between the last renter and myself.....
azrving
Oatman
Posted: 04/12/19 06:57am Link  |  Quote  |  Print  |  Notify Moderator
Buy a gallon of pine Sol or something like that. Swab the bowl and dump a bunch of it in the black tank. You can keep pouring a little in the bowl now and then to nurse it through your time with it.
janstey58
Glenwood, IA
Posted: 04/12/19 10:55am Link  |  Quote  |  Print  |  Notify Moderator
The cheese guy made me belly laugh, LOL!!
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
turbojimmy
New Jersey
Posted: 04/12/19 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
The rental place might have dropped a tank tab in there. They're deodorizing tabs that also claim to help break down waste. They can have a strong, sweet smell.
1984 Allegro M-31 (Dead Metal)
the bear II
Torrance CA.
Posted: 04/12/19 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
I would suspect a toilet deodorizing chemical was added and activated once liquid hit it. Something like Thetford AquaKem
Knowharm
Us
Posted: 04/12/19 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
FYI. Cheese guy made me laugh too now that I re-read it after getting some sleep. I don’t know what the odor was, but I febreezed the crud out of the toilet and the odor has not returned. Pot heads should buy stock in febreeze. [emoticon] thanks for everyone’s advice and humor.
