RV.Net Open Roads Forum: Wasps in camper. Best way to remove?
 > Wasps in camper. Best way to remove?
JoshuaH
Jefferson City, Mo
Posted: 04/12/19 07:08am Link  |  Quote  |  Print  |  Notify Moderator
I went in our camper yesterday, probably been a month since I've been inside and found 3 red wasps climbing around on the AC unit in the roof.
So what is a good way to get rid of them? I don't really want to spray wasp killer in the camper. I thought about maybe trying to suck them up with my shop vac?
I'm guessing they are building a nest in the AC unit so I probably need to take the cover off, not looking forward to that.
Any ideas how they got in? It is sealed up pretty tight, I'm guessing through the AC unit.
Any suggestions would be appreciated.
drsteve
Michigan
Posted: 04/12/19 07:25am Link  |  Quote  |  Print  |  Notify Moderator
Ortho Sevin powder. Dust the nest with it. It takes a couple of days to kill them.
1991 Palomino Filly PUP
Walaby
Georgia
Posted: 04/12/19 07:28am Link  |  Quote  |  Print  |  Notify Moderator
Might consider waiting until dark/dusk. Take cover off A/C, spray next with wasp spray (from outside obviously). At dusk/dark, they all congregate at the next for rest and relaxation.
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
wanderingaimlessly
SOBOVA
Posted: 04/12/19 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Sevin duster after dark and dust the box heavily. it may take a day to get them all.
Take the cover off the next evening and deal with the nest then.
After getting as many as you can, spray the outside box with a spray like this tractor supply spray which will also deter them from reappearing after you put the cover back on.
ppine
Northern Nevada
Posted: 04/12/19 08:26am Link  |  Quote  |  Print  |  Notify Moderator
I like the spray that is "electrostatic" designed for stinging insects. I bought a house with wasps under all of the eaves of the house. Hit them early in the morning when they are all in the nest. The can is green and yellow, I forget who makes it.
Tom/Barb
Oak Harbor, Wa
Posted: 04/12/19 09:50am Link  |  Quote  |  Print  |  Notify Moderator
Shop vac. great idea.
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JK toad.
Old-Biscuit
Verde Valley
Posted: 04/12/19 09:55am Link  |  Quote  |  Print  |  Notify Moderator
IF you have wasp inside crawling around the ceiling vent then taking cover off (roof shroud) will NOT solve your problem.
Need to remove return air filter exposing the evap coil area and check for nest building------evap coil inside a seal compartment
RV A/C Units are sealed from 'access to outside'
From 'bryant rv'
myredracer
Langley B.C.
Posted: 04/12/19 10:18am Link  |  Quote  |  Print  |  Notify Moderator
Flame thrower. Don't mess around... I'm allergic to stings. Only living creature I have no sympathy for and I doubt they're important to earth's ecosystem.
Otherwise, they go to "sleep" after dark and some wasp spray should work. Wear protective clothing if you're near it. Then go in there and pull the paper nest out. There's alternatives to regular commercial wasp spray (which is toxic) like Ecosmart wasp spray, available at Walmart, Lowes, Amazon, etc.
When I was young, dad always used to say stay far away from wasp nests. Bad idea to tell kids not to do something!! Poking a nest is not good as I found out. [emoticon]
I hate CAPTCHA. CAPTCHA sux. CAPTCHA is evil. CAPTCHA needs fixing.
Gil, Deb & Dougal the Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH
2009 F250 super duty, V10, 8' bed, Hawkshead TPMS
fred42
Charlotte, NC, USA
Posted: 04/12/19 10:23am Link  |  Quote  |  Print  |  Notify Moderator
I have had similar situations where I was going to be working in a tight space and did not want to be breathing in wasp spay. I would not want to use poisons of any kind on an air circulating system. I found cleaning formula 409 was a useful spray and kills wasps and ants. When trying this or any wasp spray it is important to insure that no one involved in or near the effort is known to have a life threatening response to wasp/bee stings.
SAR Tracker
Central Oregon
Posted: 04/12/19 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
Spectracide
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
