RV.Net Open Roads Forum: Wasps in camper. Best way to remove?
 > Wasps in camper. Best way to remove?
ppine
Northern Nevada
Posted: 04/12/19 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
thanks to SAR tracker.
Bobbo
Wherever I park
Posted: 04/12/19 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
If you don't like the pesticide kind of wasp spray, WD-40 will kill them just as fast.
Bobbo, Linda and the furry kid (45 pound rescue)
Dave H M
IL
Posted: 04/13/19 07:00am Link  |  Quote  |  Print  |  Notify Moderator
listen to the ole biscuit. If they are inside the camper, they should (i said should) not be building outside in the condenser unit. Might be interesting to find the avenue of how they are getting in the camper.
Fizz
Ottawa, Canada
Posted: 04/13/19 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Set out one of those sugar-water traps. Won't take long to lure them in.
dewey02
The Mid-South
Posted: 04/13/19 11:04am Link  |  Quote  |  Print  |  Notify Moderator
seaeagle2
seattle
Posted: 04/14/19 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
I had a wasp nest in the eve of the house, all I could see was a small hole. I set up a shop vac with a long hose. As the wasps exited the hole, they would get sucked into the shop vac. As the ones in the field returned to the nest and went to enter the hole, they wold get sucked into the shop vac. After a couple days, there's no one left bringing food the the ones in the nest and they die off. If you don't have clear access to spray the actual nest, this is the way to get rid of them. ( if you just seal up the hole, they just chew a new opening and it might be through the sheetrock in the living room).
2014 F 250 Gasser
2019 Outdoors RV 21RD
"one life, don't blow it", Kona Brewing
"If people concentrated on the really important things in life there'd be a shortage of fishing poles" Doug Larson
drsteve
Michigan
Posted: 04/15/19 08:53am Link  |  Quote  |  Print  |  Notify Moderator
seaeagle2 wrote:
If you just seal up the hole, they just chew a new opening and it might be through the sheetrock in the living room.
Had a nest of yellow jackets in the siding once. Hosed the entrance hole down with Raid, and they found their way into the basement. Hundreds of them...
1991 Palomino Filly PUP
Campinfan
Washtenaw County, Michigan
Posted: 04/15/19 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
Put Pine Sol in a garden sprayer ( I mix it 50-50 with water but you can go full strength). Learned this from a roofer. It works great plus you do not have to get close.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
packnrat
soon to be the state of Jefferson U S A
Posted: 04/16/19 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
get the rv very cold, wasps hate the cold. they will move on. but going to co$t you.
never kill them off inside any wall. as it rots, and attracts roaches, thus more rot.
i like the vacuum deal.
2006 F250 4X4 auto 6.0 short bed
2001 sunnybrook 24 ft
1984 cj7 built up a bit
kg6tgu
never too many toys, just not enought room to keep them
one dog who belives she is the master. rip 12 12 2007
12 loving years and loyal to the end.
just out having fun
dcmac214
SW OKLA
Posted: 04/19/19 11:23am Link  |  Quote  |  Print  |  Notify Moderator
Whatever you do, do NOT try spraying them with Off or any other insect repellent. Yes, voice of painful childhood experience.
