RV.Net Open Roads Forum: Tech Issues: Ultraheat less expensive alternative?
 > Ultraheat less expensive alternative?
GordonThree
Northern Michigan
Posted: 04/12/19 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
Looking for suggestions for less expensive alternative to ultra heat 12v self regulating cable?
Have an outdoor pump that I want to wrap the pump head with and also about six feet of pipe.
Looks cheaper to buy generic 120v stuff and a small inverter.
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
pianotuna
Regina, SK, Canada
Posted: 04/12/19 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
Gordon Three,
Stay with 120 volt.
Regards, Don
grizzzman
salt lake city, Utah
Posted: 04/14/19 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Here is self regulated 12 volt heat cable on ebay.Heat cable
2013 Ford F150 EcoBoost SuperCrew BFG KO2 10 Ply
2016 Rockwood Mini Lite 2504S. TM2030. SC2030 , Grape solar BT 40 Amp PWM
640 Watts Solar. Costco CG2 208 AH and Group 31 192 AH Batteries
400 Watt and 2000 Watt Inverter's hard wired.
Boondocking is my Deal
profdant139
Posted: 04/14/19 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
If you have plenty of 120v power, that is the easier solution. If you don't have hookups, I would stay with 12v -- that way you don't need to turn on the inverter.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
