RV.Net Open Roads Forum: Best Sealant for SIDES (Vertical) portions of trailer?
 > Best Sealant for SIDES (Vertical) portions of trailer?
Baja Man
Inland Empire, CA
Posted: 04/12/19 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
In the past, I have personally resealed all of my previous trailers and motorhome roofs. I am fairly handy and do most of the maintenance work myself (home, boats, trailers, etc).
Since I am not too fond of heights... and my older age....I do not want to risk injury performing this service....therefore....
I am having the roof completely serviced on the new to me 2009 Tahoe Toyahauler. This will include Dicor lap sealant on all protruding items (14" air vents, plumbing vents, etc.) and a complete roof sealant (Dicor sealant applied to entire EPDM roof membrane). I will also have them install all new 14" plastic vents (4) and Max Air II covers over all vents (4).
When I get it back from this service I would like to seal ALL items that are on sides of trailer (vertical sections) from the top roof (rain gutter) to the bottom edge between trim that separates the rock guard from the fiberglass sides of trailer, and all clearance lights, porch light, and ANYTHING screwed to side of trailer.
With that said, over the past several years I have used the following two sealants for VERTICAL surfaces:
1. Dicor NON-Self Leveling sealant
2. GeoCel ProFlex clear sealant
QUESTIONS:
A. Are these still (1 and 2 above) the preferred sealants for vertical surfaces?
B. Are there other sealants that have proven more advanced than these sealants?
c. What tips/suggestions/advice can you share about sealing all of the vertical surfaces I have mentioned above?
Thanks!
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 trans
2009 Thor-MVP RV- Tahoe 284SA
2006 Tracker Pro Guide V 16 WT (Mercury 60hp 4 stroke)
Veebyes
Posted: 04/12/19 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Coming from the marine world my usual goto products for water sealing are marine ones.
Try to be neat about it by taping either side of joint area, applying product, run an ice cube along the bead to make it smooth & remove tape shortly after before the product cures.
2007 Alpenlite 34RLR
garym114
Bluff Dale, Texas
Posted: 04/12/19 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
GeoCel ProFlex sealant for vertical surfaces, comes in colors, easy to smooth out.
loggenrock
New Hampshire
Posted: 04/12/19 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
Last season I discovered Lexel, available at Home Depot. Flexible, crystal clear.
Two and a hound in a 2015 Coachmen Prism "B+"...pushed by '09 Suby Forester
First 50 done, working on the second pass! Nunavut - we'll see...!
2005-2015 Roadtrek 190P
1993-2005 Northstar Soft-Side TC
1989-1993 Backpacks & Tents!
1967-1977 Family TT's
loggenrock
New Hampshire
badboy368
OHIO
Posted: 04/13/19 02:02am Link  |  Quote  |  Print  |  Notify Moderator
Nothing but Pro-Flex for me.
40' pusher,350 turbo cat, pullin a 37' trailer haulin a drag car. oh yea baby
buc1980
houston tx
Posted: 04/13/19 08:51am Link  |  Quote  |  Print  |  Notify Moderator
I try Dicor for vertical seal and I am not impress.I try the reputation of Dicor and they let me down.I think to remove it and use Geocel pro flex RV after I read about it.Don't use Dicor .
2017 Ford F350 DRW,2005 Kountry Star 35ft,14750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.
bob213
Fresno, CA
Posted: 04/13/19 11:10am Link  |  Quote  |  Print  |  Notify Moderator
And unlike other caulks that you have to remove to do a repair, Lexel will stick to lexel, so you can go over it to do a small repair.
