RV.Net Open Roads Forum: Class A Motorhomes: Motorcycle Lift on Rear Rad
 > Motorcycle Lift on Rear Rad
Mile High
CO
Posted: 04/13/19 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone installed a motorcycle lift on a rear radiator coach? I'm just wondering if the heat from the radiator causes problems with the bike, and if the bike causes problems with airflow.
The previous owner of mine installed a CruiserLift, but maybe it didn't work out and that is why he traded - not sure.
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
wanderingaimlessly
SOBOVA
Posted: 04/13/19 11:35am Link  |  Quote  |  Print  |  Notify Moderator
If the lift is still there, you have a marvelous opportunity to find out.
Mile High
CO
Posted: 04/13/19 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
I would have to go buy the physical lift. I only have the hitch system that was welded on the back.
fuzzyface
Polk City, FL
Posted: 04/13/19 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
I had a versa-lift on the back of my rear rad Bounder, had no problems with it. Carried a small (650) yamaha on it for several years.
Linda and Mike Kruzin' in a Kountry Star
Chum lee
Albuquerque, NM
Posted: 04/13/19 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
Generally, the air coming off the engine of the motorcycle (air cooled) is far hotter than what comes out of the radiator of a diesel engine.
Chum lee
MrWizard
Traveling
Posted: 04/13/19 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
i carried a 'scoot' on the back of our rear raditor DP for 8 years
never noticed any additional heating problems to the engine
or heat damage to the bike
Radiate The Happy
1997 F53 Bounder 36s
Bill1374
northern New York
Posted: 04/13/19 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Had an Overbilt lift on the back of my Phaeton. It handled my Harleys just fine, either the Road King or Fatboy. Occasionally, I would get a bit of oil film on the engine but a quick wash would clean the bike up. Grreat way to bring your mc with you as the Overbilt is also set up to tow a toad.
KZ Montego Bay in Florida
Rockwood lite up north
2016 HD Street Glide, 12 Fatboy for cruisin
SDcampowneroperator
South Dakota
Posted: 04/13/19 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
We have seen many, side and rear radiator. never had a guest tell us of any problems. The vorticie behind the coach is plenty to overcome any slight reduction of cargo.
One guest had a neat solution to keep his 800# H/D FLHTCU clean, he made steel hoops that fit into sockets on the lift, then a vinyl zippered cover with a 8" 'hose' that went to an air scoop on the roof. The scoop and hose sent clean air down around the bike. Coach was rain & road dirty, bike was spotless.
Supercharged
Az.
Posted: 04/13/19 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
I new a guy who put a HD 74 on one and when he got there it was a trail bike.
So big a world, so little time to see.
FIRE UP
Lake Havasu City AZ
Posted: 04/14/19 12:28am Link  |  Quote  |  Print  |  Notify Moderator
Mile High,
Yes, I did just what you're asking. I installed a Hydralift on the back of our '04 Itasca Horizon 36GD with the CAT C-7 330HP. Yes, it's a rear radiator. After the install, we loaded the bike and headed out on our first trip. It involved the "Baker Grade" that's on the way from San Diego to Las Vegas. It's one pain in the bu.. grade. That coach got a bit warm on that grade, as do many. I pulled over near the top of, a pull off called Haloran Summit and stopped the coach while I got out and checked the bike to see if the heat coming off that rear radiator coach, had any affects on the Hondas paint.
Oh by the way, we were carrying an '08 Honda GL 1800 Goldwing. While the bike was quite warm, I saw no detrimental effects. As for the coach engine getting warm, it was due to a fin-clogged radiator that I didn't know I had. That condition has since been remedied.
So, to answer your question, no, there is no negative effects of the heat coming off the radiator of that coach, on the bike.
Posted By: Chum lee on 04/13/19 02:03pm
Not exactly. I ran an infrared heat gun in multiple areas of the radiator, the bike, the rear grill of the coach and more and, without a doubt, the heat coming off the rear of that coach is either equal or above that heat that comes off my Wing motor.
Scott
[image]Click For Full-Size Image.
* This post was edited 04/14/19 01:59pm by FIRE UP *
Scott and Karla
SDFD RETIRED
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
