RV.Net Open Roads Forum: Tech Issues: How do I change these LEDs?
 > How do I change these LEDs?
dedmiston
Valencia
Posted: 04/13/19 11:50am Link  |  Quote  |  Print  |  Notify Moderator
I have some burned out LED lights and I can’t figure out how to open the fixtures. Any tips?
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
bgum
South Louisiana
Posted: 04/13/19 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
Most are held by spring clips. Pull straight down.
SidecarFlip
SE Michigan
Posted: 04/13/19 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
While you are at it, clean the screen on your Fantastic Fan, it's cruddy....:
It pulls straight down as well....
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Darryl&Rita
Grande Prairie, Alberta
Posted: 04/13/19 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
Check for power and ground at the lights before replacing.
***UPDATE 2006 3500 SRW MegaCab pulling a 2007 fleetwood 5'er
Ivylog
Blairsville, GA and WPB, FL.
Posted: 04/13/19 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
I would try pushing up on the ring and turn CCW.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
How I tow.
Towing a Prius without a dolly
How I spend the winter.
HappyKayakers
Somewhere in the USA
Posted: 04/13/19 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
If you can't see any fasteners and it won't unscrew, I would use a thin knife blade to pry it away from the ceiling. You should find a small printed circuit board underneath.
Joe and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
http://happykayakers.com/
cajun70586
ville platte la.
Posted: 04/13/19 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
That’s the same ones I have they rotate ccw
ken56
Tennessee
Posted: 04/13/19 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
I have had some that screwed on and others that had a notch in the cover, rotate to line up and it falls out. as for the burned out LED's you may need to just replace the whole light. They run about 12 bucks or so.
dedmiston
Valencia
Posted: 04/13/19 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
ANSWER: The center lens pops out with a blade. Problem solved.
The outer rings are stationary.
loggenrock
New Hampshire
Posted: 04/13/19 11:01pm Link  |  Quote  |  Print  |  Notify Moderator
I have (had) the same type. The LED chips had a disappointingly short life... Initially replaced 2 fixtures with an equivalent, but kinda pricey for what they were... Created an alternative...Cabin Bright sells a NICE replacement LED chipset for ITC fixtures - see https://www.cabinbright.com/product/itc-fixture-replacement-led-set/ - I replaced the PCB in the original fixtures with a piece of roofing aluminum I cut to the same size. Drilled a 1/4" hole for the wires thru the center of the replacement square of aluminum, then adhered the new chipset right to that (serves as a heatsink, too). Re-installed the original fixture with the new board - great results! Available in various temperatures, too.
Two and a hound in a 2015 Coachmen Prism "B+"...pushed by '09 Suby Forester
First 50 done, working on the second pass! Nunavut - we'll see...!
2005-2015 Roadtrek 190P
1993-2005 Northstar Soft-Side TC
1989-1993 Backpacks & Tents!
1967-1977 Family TT's
