RV.Net Open Roads Forum: Tongue Jack Block - Need one light, strong, and tall
 > Tongue Jack Block - Need one light, strong, and tall
Baja Man
Inland Empire, CA
Posted: 04/13/19 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
I would like to have a tongue jack block that is light, strong (2000# TW), and at least 10" tall.
I need the height so that I can raise my tongue/coupler pretty high to make it easier to "unload" my weight distribution bars on my Blue Ox BXW2000 Weight Distribution Hitch.
I know I can stack the yellow blocks, and this is probably the less costly approach. It would be nice to have a single dedicated unit that I can use at home when stored and at campground.
I have made one of wood (10" tall) but it was much heavier than the yellow plastic ones even stacked to reach 10" tall. I can always make another one out of wood if it appears that this may be the best solution.
Thoughts, suggestions, etc?
Thanks!
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 trans
2009 Thor-MVP RV- Tahoe 284SA
2006 Tracker Pro Guide V 16 WT (Mercury 60hp 4 stroke)
Lynnmor
Red Lion
Posted: 04/13/19 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
Would this work for you?
myredracer
Langley B.C.
Posted: 04/13/19 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
Not quite 10", but there's this Valterra one. If going tall, the wider you can make the base, the more stable it will be. I don't think you can buy ones with a wider base though.
I hate CAPTCHA. CAPTCHA sux. CAPTCHA is evil. CAPTCHA needs fixing.
Gil, Deb & Dougal the Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH
2009 F250 super duty, V10, 8' bed, Hawkshead TPMS
Baja Man
Inland Empire, CA
Posted: 04/14/19 07:34am Link  |  Quote  |  Print  |  Notify Moderator
Also found this one for $25 by Andersen hitches, 8" tall and 2000# rated.......
Baja Man
Inland Empire, CA
Posted: 04/14/19 07:38am Link  |  Quote  |  Print  |  Notify Moderator
It may be an option....just need to verify it will fit my Bulldog electric tongue jack. Undecided if I should use something like this or the plastic risers???
Lynnmor
Red Lion
Posted: 04/14/19 07:42am Link  |  Quote  |  Print  |  Notify Moderator
There are other sizes available. The plastic blocks take up a lot of room.
Baja Man
Inland Empire, CA
Posted: 04/14/19 09:42am Link  |  Quote  |  Print  |  Notify Moderator
I was thinking of the plastic boxes for the 4 stabilizers....so the stabilizers do not have to be cranked so far down.....the "less down" they are, the more stable is the trailer
Thoughts?
Baja Man
Inland Empire, CA
Posted: 04/14/19 09:43am Link  |  Quote  |  Print  |  Notify Moderator
Looks like I may go with this one....10000# capacity is quite a bit.
Boomerweps
Hills of PA
Posted: 04/14/19 11:35am Link  |  Quote  |  Print  |  Notify Moderator
I bought one of those Valtera traffic cone jack stand supports. It's made for the bare end of the tongue jack. I put a metal skid plate on my jack and just use stacked 4x4s when connecting and disconnecting my TT to my TV. I just don't feel safe enough to use the cone to lift the front of the TT and the rear of the TV. It's a lot of weight. Plus I'm doing it in a truck pull off if heading north as I drag the TT rear pulling out my driveway before installing the WD bars. Going south, I loop through the high school bus lane for installation.
2019 Wolf Pup 16 BHS Limited
2008 Ford Exploder 4.0L
TUCQUALA
Kennewick, WA
Posted: 04/14/19 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
One thing to consider about the "thing" (!) extension is how much it would hang under the tongue, IF you leave it on the jack!!! Back of tow veh goes down in a driveway entrance or ditch in the woods, so does the tongue of trailer!! No problem if removed until needed, but another step in the hookup/unhook procedure.
'16 Outdoors Timber Ridge 280RKS
DrawTite/Reese 1200# Round Bar w/ DualCam HP
'03 EXCURSION XLT V10 4.30 Axles
