RV.Net Open Roads Forum: Class A Motorhomes: Surge Protector
 > Surge Protector
haste maker
alabama
Posted: 04/13/19 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
Is there a need for a Power Surge Protector? If so what is the one most RVer's recommend ?
Retried Teamster
2007 Allergo
MarkTwain
Northern, Ca. , USA
Posted: 04/13/19 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
Progressive Industries EMS 50 ap
rk911
DuPage County
Posted: 04/13/19 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
two versions...portable and hard wired. we have the hard wired version.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
MarkTwain
Northern, Ca. , USA
Posted: 04/13/19 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
Without a surge protector, you have every thing to loose and nothing to gain. Trusting that every RV Park owner will maintain and check their electric systems on a regular schedule is a foolish bet??????
msturtz
Washington
Posted: 04/13/19 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
I have used Progressive Dynamics and Surge Guard. I have had great luck with both. I only recommend the EMS versions which have the active monitoring and will disconnect at any time when detecting most power problems: low voltage, high voltage, open ground, open or floating neutral and so on. The basic surge only versions only protect against power surges.
FMCA member
old guy
Oregon (pronounced Or e gun)
Posted: 04/14/19 02:00am Link  |  Quote  |  Print  |  Notify Moderator
cheap insurance
georgelesley
Tennessee
Posted: 04/14/19 04:51am Link  |  Quote  |  Print  |  Notify Moderator
Get one that shuts off power if voltage drops too low, unless you enjoy buying AC units. Ours saved us a few times last summer.
George & Lesley
2014 Itasca Sunova 33C, 2019 Jeep Cherokee Lattitude Plus toad, Demco/SMI towing system
azrving
Oatman
Posted: 04/14/19 04:58am Link  |  Quote  |  Print  |  Notify Moderator
I have 30 amp hardwired progressive. It hurt to buy it but when you read about how much damage can be done I felt I had to buy one. Search RV improper wiring of things like pedestals where ELECTRICIANS wire them wrong and do thousand of dollars of damage.
It's good to read and familiarizing yourself with everything from simple corrosion of the plug end causing lost grounds or open neutral or shooting 240 volts through an appliance on a 50 amp rig.
People have died from "hot skin" problems. RVs have their quirkey, expensive and dangerous side. The cord is plugged in over and over, it's in a wet/damp poor environment, the pedestals are worked on by incompetent people. Cord terminals should be kept clean, test pedestals, check RV for hot skin. Kids and pets are more easily killed by hot skin.
* This post was edited 04/14/19 05:39am by azrving *
haste maker
alabama
Posted: 04/14/19 06:46am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info, I will be getting the PROGRESSIVE INDUSTRIES EMS-PT50X Portable RV Surge Protector (50 A)
Ava
Vancouver Island. BC Canada
Posted: 04/14/19 08:30am Link  |  Quote  |  Print  |  Notify Moderator
My 30 amp hard wired Progressive unit with remote display has activated with low voltage, and high voltage, no ground and recently with a reversed polarized plug.
 > Surge Protector
