RV.Net Open Roads Forum: Tech Issues: Atwood 6 gal DSI HWH "issue"
 > Atwood 6 gal DSI HWH "issue"
loggenrock
New Hampshire
Posted: 04/13/19 11:11pm Link  |  Quote  |  Print  |  Notify Moderator
This began the end of last season - getting rig ready for coming travel season, issue still present.
HWH fires when turned on, runs about 5 seconds, goes off. This repeats for a total of 3 times. Turn off switch to HWH, turn back on - fires once, stays lit.
Anyone got an idea as to why it is doing this? Thanks! ST
Two and a hound in a 2015 Coachmen Prism "B+"...pushed by '09 Suby Forester
First 50 done, working on the second pass! Nunavut - we'll see...!
2005-2015 Roadtrek 190P
1993-2005 Northstar Soft-Side TC
1989-1993 Backpacks & Tents!
1967-1977 Family TT's
bid_time
Michigan
Posted: 04/14/19 06:29am Link  |  Quote  |  Print  |  Notify Moderator
Clean the flame proofer and see if that helps. It's the long tubular thing sitting above the flame. Just very lghtly polish it with some every cloth.
enblethen
Moses Lake, WA
Posted: 04/14/19 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Clean the burner tube and ignitor/flame sensor.
Inspect the porcelain portion of the ignitor/flamesensor for cracks.
Clean multi-wire connector on circuit board.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
loggenrock
New Hampshire
Posted: 04/14/19 07:38am Link  |  Quote  |  Print  |  Notify Moderator
OK - will try cleaning as mentioned! Will report back! ST
loggenrock
New Hampshire
Posted: 04/14/19 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Follow-up.... So, dissected the DSI on the heh today, made sure multi wire plug was well seated, carefully cleaned ceramic electrode, brushed out inside of heating tube. Back together, it fired right up. Can't tell which thing helped, guessing a combination of everything. But back in service for now! Appreciate the suggestions. ST
loggenrock
New Hampshire
Oops!!! Double-posted!!! ST
* This post was edited 04/14/19 08:20pm by loggenrock *
enblethen
Moses Lake, WA
Posted: 04/14/19 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Easy fix!
This is something that is on my list of spring start up. Clean refer, burner area, clean furnace and clean water heater. Check all connections.
