RV.Net Open Roads Forum: Towing: good tires
Search only in Towing
Open Roads Forum  >  Towing
 > good tires
cav123
home
Posted: 04/14/19 07:24am Link  |  Quote  |  Print  |  Notify Moderator
hey guys had not been on in a while so trying to catch up abit,but here is a question I have a 2013 29ft Springdale travel trailer that needs replacement tires before we go camping again the tires had never been replaced and are in bad shape any ideal on a good set of tires that will hold up pretty good price is no issue,I have been looking at maxxis and a couple of other brands tires now are ST 225/75R 15,someone that I know said that the 15"tires are getting hard to find
dockmasterdave
florida
Posted: 04/14/19 07:36am Link  |  Quote  |  Print  |  Notify Moderator
Maxxis, Goodyear endurance and the newer Carlisle radial trail are supposed to be the best. I have Maxxis on the TT and Carlisle on a cargo trailer. Over 2 years on each with no problems. My Maxxis will time out this year at 5 years since manufacture. They were dated almost 3 years old when bought new. Maxxis said if you buy from them directly the tires SHOULD be 2 years old or less. I'm changing mine. Not worth having a blowout on the road.
2014 F 150 ecoboost
2010 F 150 4.6L
2007 ranger
09 Amerilite 21 (modified)
2013 Bendron 14' enclosed cargo
2011 4x8 open cargo
MFL
Midwest
Posted: 04/14/19 07:39am Link  |  Quote  |  Print  |  Notify Moderator
Provider....Carlisle HD....Endurance....All new style, better built, run cooler, and high speed rated.
Jerry
Bionic Man
Colorado
Posted: 04/14/19 07:51am Link  |  Quote  |  Print  |  Notify Moderator
With a 15" rim, I would switch to LT.
If you are stuck on an ST tire, I think Endurance is the best.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
Lynnmor
Red Lion
Posted: 04/14/19 07:52am Link  |  Quote  |  Print  |  Notify Moderator
I would Google: st225/75r15 made in USA
Lynnmor
Red Lion
Posted: 04/14/19 07:53am Link  |  Quote  |  Print  |  Notify Moderator
I don't think you will find that size in an LT.
Cummins12V98
on the road
Posted: 04/14/19 08:37am Link  |  Quote  |  Print  |  Notify Moderator
GY ENDURANCE has a stellar record, US Made at a fair price!!! Tow at 70-75 no problem if that's your thing.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Bionic Man
Colorado
Posted: 04/14/19 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Quick search found this one. Would need to check the load rating.
Wrangler
If you played with the tire size a bit you would have more options.
azdryheat
Tucson, AZ
Posted: 04/14/19 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Stay away from anything made in China
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
Posted: 04/14/19 09:42am Link  |  Quote  |  Print  |  Notify Moderator
Wrangler
The OP already has literally dozens of 15" trailer tires to choose from.
LTs in 14-15" are virtually non existent and not the right application for 14-15" trailer rims. The one you posted has like 1800lbs capacity. You can do far better with ST tires.
Not sure whypeople always chime in with the most obscure solutions to problems that don't exist, on this forum.
To the OP, I've had a couple sets of Kenda Karriers with good luck. Mid priced, high speed rated. One set has been sitting in the weather for the last 4+ years with no sign of cracking or degradation.
03 Arctic Fox 860
07 Dodge 2500 deezul
"Obviously I don't want to overload my truck and be unsafe, but the reality is the truck is way more capable than the 10K GVWR they put on the sticker.
KJ"
 > good tires
